'77 KZ650 Shifting Problems
  • Trackz440
  • Trackz440's Avatar Topic Author
15 Sep 2026 07:32 - 15 Sep 2026 07:33
#927563
I've been trying to diagnose this problem all summer. The shifting on my 2015 Vulcan S is click click easy peasy.
The shifting on my KZ650 started out more of a clunk clunk. Very heavy shifting but also 40 years older. Over the summer it got worse and when shifting up and down the clunk was accompanied by a metallic clunk just as the clutch engages. Seems worse from neutral to 3rd.
With the bike on the center stand, rocking the back wheel back and forth in any gear, all seems normal tight and quiet.
I re adjusted the clutch.
I changed the oil.
Clutch release mechanism, removed, cleaned and re-lubricated. Nothing has changed on it since the bikes restoration.Clutch readjusted to give maximum throw.Still clunks and hard to shift
Found too much play in the clutch basket
Clutch basket removed, rivets machined off, new rubber dampers purchased from UK installed, backing plate welded on, clutch re installed.
Still hard to shift. Still clunks (metal on metal) when letting clutch out most of the time unless I am shifting at over 6000 rpm. Then it seems to shift smoothly.
Could my problem be a shifting drum issue???
2015 Vulcan S 650 - Summer Ride
1967 Samurai A1 250 Restoration Completed - For Sale
1980 KZ 750E Restoration Started
1977 KZ650 C1 Restoration Complete - Favorite Ride
1968 Honda CB450 Hellcat Restoration Complete, Sold
1981 KZ440 Restoration Completed,Sold
1974 H1E Restoration Completed Sold
Last edit: 15 Sep 2026 07:33 by Trackz440.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: '77 KZ650 Shifting Problems
15 Sep 2026 08:08
#927565
As well as the clutch basket there are "cush drive" rubbers between the starter clutch and 1st motion shaft (not an easy job to access !!!)
The following user(s) said Thank You: Trackz440
  • Nessism
  • Nessism's Avatar
  • Away
15 Sep 2026 08:10
#927566
I suspect the clutch plates are slightly warped, causing drag when running.  I've experienced this issue on different bikes before, and replacing the friction and metal clutch plates fixed the problem.
Also, make sure your shift shaft hasn't damaged the side cover or transmission cover.  If the shaft wollows around it makes the shifting impercise.
  • Trackz440
15 Sep 2026 09:19
#927574
I put a completely different set of clutch plates and friction plates in when I changed the basket dampers. Exact same problem. :(
  • Trackz440
15 Sep 2026 12:52 - 15 Sep 2026 13:10
#927585
With the bike on the center stand, in gear, I can rock the wheel back and forth and get none of the clunking. I'm now leaning towards the shifter assembly?
Last edit: 15 Sep 2026 13:10 by Trackz440.
  • Injected
  • Injected's Avatar
15 Sep 2026 13:21 - 15 Sep 2026 13:24
#927587
Did you check the shift forks? they can end up getting bent/warped over time. Its unusual but it does happen, more often from abuse like drag race quick shifting or air shifter use (more pressure on fork ends)
I have have owned and worked on a lot of KZ650's and the only time I ever had a shifting issue was on a drag bike.
The only other "clunking" I ever had was worn out clutch hub rubbers. Like previously mentioned the trans cover bushings can get sloppy over time causing binding.
1978 KZ650B2 modified project
Last edit: 15 Sep 2026 13:24 by Injected. Reason: sp
  • Trackz440
15 Sep 2026 13:29 - 15 Sep 2026 13:43
#927588
I restored the bike 3 years ago. Shifter forks were good then, bike shifted good for the first year + but has progressively got worse. I've only driven it about 1500 km. Never abused.
I haven't yet opened up the crankcase as that will be my last resort. Can you change the shift forks from underneath without pulling the engine?
Last edit: 15 Sep 2026 13:43 by Trackz440.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
15 Sep 2026 14:09
#927589
You said the clunk occurs when letting the clutch out ? By this point the shifting is done and what is happening is a load change between the primary drive and the transmission?
  • Trackz440
15 Sep 2026 14:32
#927592
That's what I first thought at first but I tried to duplicate the clunk with the engine off and rock the back wheel back and forth. It doesn't. Is it possible the shifter detent is only half shifting and then as I let the clutch out it slams into the next gear?
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
15 Sep 2026 15:39
#927595
I guess its possible but don’t forget when the engine is off there is no load on the primary drive
  • Injected
  • Injected's Avatar
15 Sep 2026 18:23 - 15 Sep 2026 18:48
#927599
No you can't do that on a 650/750 as the oil filter housing casting is in the way. No way to drop the forks down.
On the Z1 you can do it with some mods, drag bike guys do it all the time at the track. On the Z1 the shift drum/forks are clear of the oil filter housing casting.
The 650/750 engines rarely suffer from shifting malfunctions unless something is reassembled wrong or a part is extremely worn out.
Never ever seen a shifter drum issue, mostly shifter fork end wear or shift shaft mechanism issues (binding) Its very easy to check the shifter mechanism on the bike if you haven't already confirmed it.
If this happened after a rebuild and it was working OK then, it has to be wear related. Something may have looked OK but was on its way out.
Last edit: 15 Sep 2026 18:48 by Injected. Reason: sp
  • Trackz440
27 Sep 2026 19:48 - 27 Sep 2026 19:49
#927965
I'm getting desperate.
I adjusted my cam chain, hoping..... but still the same deal.But I did discover something else on my return ride.
I drove into my garage, pulled in the clutch, coasted a bit and stopped. Let out the clutch and clunk, the metal on metal sound.
Pulled in the clutch, let it out again, nothing.
Pulled in the clutch, backed the bike up a foot, let out the clutch, nothing.
Pulled in the clutch, manually pushed the bike forward, let out the clutch, clunk, metal on metal sound.
Tried this several times with the same result.It appears when I push the bike forward manually and stop, then let out the clutch, as the engine is taking up the play in the transmission, I get a nasty metal on meal clunk.
I next put the bike back on the center stand, put the trans in 1st gear to check the total transmission play. Rotated the back wheel and got about 1.25" of wheel travel. (The KZ750 I restored last winter had about 2.25" in the same test and didn't have the clunk that I have.)
I thought bearing? But I have no excessive noise or vibration while driving.
Last edit: 27 Sep 2026 19:49 by Trackz440.
