Head match
  • bound
  • bound's Avatar
  • Away
  • If you ain't HURTIN' you ain't LEARNIN'!!
Re: Head match
31 Oct 2026 17:17 - 31 Oct 2026 17:20
#928835
Yeah but it wasn't clear on the years see now I see all the way up to 2005 but my problem is what if I bought another specter how would I be able to tell or if I wanted to buy another respecter how can I tell that that's not a bathtub head on it
The bathtub head only appeared on the 83-84 gpz1100 and 84-85 zn1100 ltd and you would be hard pressed to find one anyways. They are visually identical on the outside so you can't really tell but so I wouldnt worry too much about it. Really just make sure you dont buy a cylinder head from a kz1000 csr because they have a mechanical tach drive in the head which you probably don't need. However, like others have said it would make much more sense to just fix the threads on your head you have. I prefer threaded inserts because I know they won't break. If you're dead set on buying a cylinder head, these are the bikes to chose from: 81-82 kz1000k ltd, 81-83 kz1000j kz1100a shaft , 82-83 kz1000r elr kz1100d spectre, 82-05 kz1000p police.
1982 KZ1000M2 CSR
1983 KZ440D5 LTD
1985 GPz 550A2
Craig
Last edit: 31 Oct 2026 17:20 by bound.
  • lovethemkzs
  • lovethemkzs's Avatar Topic Author
Re: Head match
31 Oct 2026 17:35
#928836
I'm glad you said that because I was looking at a CSR 1000 and I'm figuring hey 82 1000 CSR if I can find one cheap enough cuz they wanted $1,000 for that bike but I'm glad you responded with that I can knock that off my possibility list thank you
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Head match
31 Oct 2026 17:42
#928837
If  CSR is all you can find for the right price it only needs a blanking plug
  • lovethemkzs
Re: Head match
31 Oct 2026 18:00
#928838
Thank you guys I don't think I will be bothering you anymore for this subject anyway LOL have a great weekend
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Head match
31 Oct 2026 19:56 - 01 Nov 2026 06:00
#928839
In my observation, these features are typically found on bathtub heads, that other models do not share:
1. Nibs on vertical fin tips
2. A's in intake passages
3. Threaded hole
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 01 Nov 2026 06:00 by daveo.
  • lovethemkzs
Re: Head match
01 Nov 2026 18:38 - 01 Nov 2026 18:39
#928856
I thought about I figured I had no more questions but I see an 83 engine KZ 1100 for for a couple hundred dollars has low compression but it's a 83 KZ 1100 a well nobody was talking about A models I guess they're not compatible or can I take the barrels and the head and switch it
Last edit: 01 Nov 2026 18:39 by lovethemkzs.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Head match
01 Nov 2026 19:28
#928858
Might be a good choice, though there will be significant investment beyond that to rebuild whatever you decide to use.
Check part numbers for the exact engine/bike model on:
www.cmsnl.com/kawasaki_model11368/
...to determine compatability.
  • TexasKZ
  • TexasKZ's Avatar
Re: Head match
01 Nov 2026 19:36
#928859
