Head torque question
  • shifterkart26
  • shifterkart26's Avatar Topic Author
11 Sep 2026 12:24
#927447
I was advised to check/re-torque the head. Is it recommended that the nut be backed off slightly and then re-torque? TIA
  • Nessism
  • Nessism's Avatar
Re: Head torque question
11 Sep 2026 14:30
#927451
Yes, back off just enough to get the nut moving, then switch directions.  The nuts may stick, and give off a loud crack noise.  Don't use a delicate torque wrench, the shock may break the mechanism.  A beam type would be safe.
The following user(s) said Thank You: sf4t7, shifterkart26
