1980 KZ550 Starter turns but Engine dosent
  • Sammar
  • Sammar's Avatar Topic Author
08 Sep 2026 07:20
#927364
Hey all,
On my KZ550 The engine turns manually. I got the electrical working and hit the starter. Starter whirred but the engine didnt turn. I removed the starter and bench tested it its working. I checked the gears on the starter and the starter clutch gear and they look fine. The Starter clutch turns only counterclockwise by hand. I am stumped any suggestions?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: 1980 KZ550 Starter turns but Engine dosent
08 Sep 2026 08:40
#927367
Try taking the plugs out so there is less load on the starter clutch, if the motor spins the starter clutch is likely slipping under load
  • Sammar
08 Sep 2026 09:21
#927369
I did try that the plugs are out and still doesnt turn over. Starter just spins
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 Sep 2026 09:47
#927370
Does sound like starter clutch
  • Sammar
08 Sep 2026 10:27
#927371
Hmm yea i guess so I havent done that before is it difficult?
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
08 Sep 2026 11:16 - 08 Sep 2026 11:17
#927374
Very!!,.......but usually sounds like bad bearing when slips, ..and degrades gradually. .
Last edit: 08 Sep 2026 11:17 by hugo.
  • StreetfighterKz
  • StreetfighterKz's Avatar
08 Sep 2026 11:32
#927376
Just a thought: Did you or the previous owner rebuild the starter motor?  It could be spinning backwards which would cause it to freewheel the starter clutch.  Just grasping at straws but I’ve heard it happening.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Sammar
08 Sep 2026 11:45
#927377
I didnt rebuild it and it is running clockwise.
  • chopper1963
  • chopper1963's Avatar
09 Sep 2026 07:18
#927385
Will it push start?
  • F64
  • F64's Avatar
  • 81-KZ440D2
09 Sep 2026 07:34 - 09 Sep 2026 07:43
#927388
yeah, it doesn't look as easy as my kz440
81-KZ440-D2.
LIC, NY
Last edit: 09 Sep 2026 07:43 by F64.
  • F64
  • F64's Avatar
  • 81-KZ440D2
11 Sep 2026 09:00
#927443
wait
which engine oil are/were you using?
81-KZ440-D2.
LIC, NY
