Cam Rubber End Plugs
- Len1026
04 Sep 2026 08:19
What sealant should I use on the half moon end plugs? Mine started leaking in about a year. I used a small amount of Ultra Black RTV. I think they are aftermarket plugs but they seemed to seal nicely when installed. I just ordered OEM plugs hoping they will work better.
Thanks
Len
1982 LTD 750
1981 CB900 F
Thanks
Len
1982 LTD 750
1981 CB900 F
1982 KZ750 LTD
1981 CB900F
1981 CB900F
- zed1015
Re: Cam Rubber End Plugs
04 Sep 2026 08:49 - 04 Sep 2026 10:24
There should be no issues with either stock or aftermarket half moons if sealed correctly with RTV.
I use VTECH Vital black 600 degree RTV.
I set them level in the head with a straight edge/steel rule and leave overnight to cure before fitting the gasket and cam cover.
Just before fitting the gasket peel off any excess RTV from the inside and apply a light smear of RTV across the top of the end plug making sure it overlaps the joints either side.
Once the cover is bolted down peel off any excess RTV from the outside and you are done.
Last edit: 04 Sep 2026 10:24 by zed1015.
The following user(s) said Thank You: asphalt900, sf4t7, Len1026
- StreetfighterKz
04 Sep 2026 08:51
I’ve always used Yamabond4. It’s a semi-drying liquid gasket sealer. A thin skim coat is all it takes, no need to gloop it on. I RARELY use anything else on engines.
a.co/d/03bhX7Sn
Later, Doug
a.co/d/03bhX7Sn
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- asphalt900
04 Sep 2026 09:36
I've used Yamahabond#4 forever but same as Hondabond equivalent. Like as mentioned, don't be in a rush! Half moons installed with product, install cam cover, clamp down and let the bonding agent cure overnight. Beware, a lot of those aftermarket moons like to slip out under pressure. Crap that Z1 enterprises sells will do that to you, just not the same as original. This is thru personal experience.
The following user(s) said Thank You: Len1026
- sf4t7
04 Sep 2026 11:24
I've had good success with the aftermarket machined aluminum cam end plugs I got them from Blue Moon on ebay, but there are other sources also. I think Z1parts.net also sells them, their stuff is high quality. Same as previously stated, THIN coat at head install plugs flush with a straightedge for checking. Let cure and then THIN coating where cover meets plug and install cover. Never had a leak this way.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: MFP-Joe, Len1026
- Cra-z1
05 Sep 2026 18:35
That's all I do now is the machined half moon plugs from Blue Moon on ebay. I also order drain plugs and the carb tees. He makes good products. You need to check the fit of each plug first because sometimes you need to file the end of one or two of the castings down a bit. some castings are just a bit wider than the machined plug. I use Yamabond/Hondabond to seal them.
The following user(s) said Thank You: sf4t7, Len1026
- RonKZ650
05 Sep 2026 20:28
Yamabond #4, and after they start leaking get rid of them. Once they leak you can add 100x different sealer, and 100x they will leak.
- slmjim+Z1BEBE
06 Sep 2026 03:35 - 06 Sep 2026 03:36^^^ Exactly that ^^^That's all I do now is the machined half moon plugs from Blue Moon on ebay. I also order drain plugs and the carb tees. He makes good products. You need to check the fit of each plug first because sometimes you need to file the end of one or two of the castings down a bit. some castings are just a bit wider than the machined plug. I use Yamabond/Hondabond to seal them.
Not unlike some firearms mods wherein the vendor states, "Some fitting may be necessary."
We bought some sets of the light blue APE plugs decades ago that required light fitting of a very few of the bored half-moon ends in the head to seat fully. A couple / three strokes with a points file. Or, just trim a tiny burr parallel on the inside with a thin, sharp blade. Once fitted correctly & sealed, they're very unlikely to weep in the bored half-moon cutouts.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 06 Sep 2026 03:36 by slmjim+Z1BEBE.
The following user(s) said Thank You: sf4t7, Cra-z1, Len1026
