Z2 engine cases
- Cra-z1
Z2 engine cases
23 Aug 2026 14:24 - 23 Aug 2026 14:24
What are 74 z2 engine cases worth in the US. Guy local has cases but thats it.
Last edit: 23 Aug 2026 14:24 by Cra-z1.
- Mcdroid
- Gone Kwackers
Re: Z2 engine cases
23 Aug 2026 15:11 - 23 Aug 2026 15:14
Tricky question. Probably for someone assembling a Z2, a higher price is warranted. I'm guessing that there are no more than 20 - 30 Z2's in this country...and as those come up for sale, they are being sent back to Japan, where a market still exists. With a little work, a Z2 case could work for a Z1, but why would you, when there are still Z1 cases bumping around? I've a Z1B case set that I bought for about US$100.00, so a Z2 case set should bring at least that, unless you have a Z2 needing a case replacement...in which event, it depends on how hungry the buyer would be. People looking for Z2 parts in this country are uncommon.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 23 Aug 2026 15:14 by Mcdroid.
- Cra-z1
Re: Z2 engine cases
24 Aug 2026 08:12
Yes my thoughts exactly, I think he wants to much ,$500. He knows they are rare but that's the problem, so are the people that would need a set
- Mcdroid
- Gone Kwackers
Re: Z2 engine cases
24 Aug 2026 09:03
Yes, I suspect he will be sitting on those cases for a long time...at $500.00.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- StreetfighterKz
Re: Z2 engine cases
24 Aug 2026 11:23Just because something is rare; doesn’t mean it’s valuable…I think he wants to much ,$500. He knows they are rare
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Mcdroid, Wookie58
- asphalt900
Re: Z2 engine cases
25 Aug 2026 04:30
You wouldn't perhaps have the Engine number of those cases would you Cra-z1? Too bad it's missing the other stuff, crank/cylinder...
- Cra-z1
- Mcdroid
- Gone Kwackers
Re: Z2 engine cases
25 Aug 2026 10:50 - 25 Aug 2026 10:52
If anyone cares, and if the same assembly patterns resembled the Z1 series (e.g. frame and motor number were within 200-300 of each other), then this case came from a motorcycle assembled in either October or November 1974. Info comes from data compiled by John Brookes...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 25 Aug 2026 10:52 by Mcdroid.
