Oil flow chart for 1975 kz400
- spyshot
03 Jul 2026 04:38
I’m getting conflicting information on whether there should be oil inside the generator cover. I found a post on here that says there should be while there’s a YouTube video with the guy doing an engine Rebuild says it’s dry in there. Does anyone have an oil flow chart? I cannot find one in my service manual or anywhere else on the web.
1975 KZ400
- H1Vindicator
Re: Oil flow chart for 1975 kz400
03 Jul 2026 06:46
probably wet. since the starter chain is under there. kz400.com has a couple of kawasaki factory service manuals for the 400/440. avoid the forums there. possible malware.
03 Jul 2026 06:49
There is a manual here on the forum in the "filebase"
- gd4now
- Denco where did you go?
03 Jul 2026 07:12
I do not know if oil belongs there are not, but there is a manual in the file base that shows oil flow and explains oil flow, Not sure if the manual you have is the same one.
kzrider.com/filebase-alias/summary/11-kz...1-kz-400-shop-manual
Page 132 is the location it begins explaining oil flow with pic
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- spyshot
03 Jul 2026 13:36 - 03 Jul 2026 13:37
So frustrating. I had that shop manual the whole time and just could not find that page...anyway, here is where I'm at. This chart makes it very hard to tell, but I think it shows no oil going to the generator cover. So I pulled my cover off and found a bit of oil in there. Maybe a couple ounces. There are no oil passages in or out; so I'm not sure yet where its coming from, probably seepage around the crankcase. I then started it up and watched for several minutes....no oil coming in. So, I think the youtube channel gearheadgeeks is correct when he says that this area is dry. I'm also not sure why there needs to be a gasket, but hey, there is a gasket on the ignition point cover too.
I guess the starter chain is not used enough to worry about lubrication?
1975 KZ400
Last edit: 03 Jul 2026 13:37 by spyshot.
03 Jul 2026 14:10
I believe there is an oil drilling in the crank under the starter clutch which is why the starter clutch has a seal. On the bigger motors there is no seal into the generator housing but there is a return passage to the sump. This allows the oil to cool the stator and return to the sump. The 400 doesn't appear to have a return so I believe should be dry
- spyshot
- H1Vindicator
03 Jul 2026 18:51
a kz400 fsm says to put an oil drain pan under the generator cover before removing it. not sure if that's for a just in case there's an oil leak or if oil is expected.
- spyshot
06 Jul 2026 11:00
See page 44 of the fsm. I don't see that notation.
1975 KZ400
