Oops! Forgot the idler roller
  • sf4t7
  • sf4t7's Avatar Topic Author
28 Jun 2026 15:50
#925348
In case you're ever wondering, if you forget to install the cam chain idler roller that goes between the block and the cylinders - it is possible to raise the cylinders about 2" without exposing the piston rings (which would be another dilemma). Then you can carefully install the roller, axle, and rubber blocks, push the cylinders back down and the problem is solved.
Don't ask me how I know, haha.
Unfortunately I didn't stop to take any photos during the "operation"
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: StreetfighterKz, Mcdroid, MFP-Joe, Kofla
  • Cra-z1
  • Cra-z1's Avatar
Re: Oops! Forgot the idler roller
28 Jun 2026 21:28
#925355
happened to me on the last z1 build, but caught it before I used the block down completely. Problem is the shaft has to go under the base gasket creating a slight problem but I got it.
  • sf4t7
29 Jun 2026 05:12
#925364
Yeah, I was lucky too. I noticed it before the head went back on. Noticed the new roller in a bag when looking for something else!
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
29 Jun 2026 05:46
#925365
Guys, you're in good company there: I once mounted the cylinder head after installing only one guide pulley at the front and one at the back! Mind you, for the rear pulley, I forgot the lower part of the chain tensioner... oops!  - Sometimes your mind is already a step ahead...As long as we noticed our errors and faults, we can fix it and it didn´t result in  a crash!
We are all only human, therefore we make mistakes, errors and nonsense. Nobody is perfect!!!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
The following user(s) said Thank You: slmjim+Z1BEBE, sf4t7, Kofla, Wookie58
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Away
02 Jul 2026 03:23
#925436
   When slmjim was hanging out at a favorite bike shop many years ago a KZ1K came in on a trailer.  Owner said he'd 'rebuilt' the motor, but now it wasn't holding oil pressure.  He forgot the O-ring between the case halves.  No apparent damage, but an expensive learning opportunity for the owner.
   In the same vein, wanna mess with someone's mind?
   If a person walks away, say, for lunch, from a bottom end on the bench after torquing case halves together,  place a new oil gallery O-ring still in the bag under the freshly-assembled bottom end.  Same can be done with that grooved copper thrust washer between the cases & the starter gear after the dyno cover has been installed.  There’s other possibilities, but you get the idea.  The more people in the audience who are in on it the better, as long as everyone can keep a straight face.  Just make sure the assembler is stopped before the first fastener is loosened.  The Lovely Z1BEBE is  totally unamused  by something similar (it's been tried...), so slmjim sez it must a male-bonding-moment sort of thing & girls just aren't built to appreciate that kind of entertainment.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Cra-z1
  • Cra-z1's Avatar
02 Jul 2026 08:16
#925444
Im not even going to mention the time I bolted the case half's together and then realized I had forgotten the cam chain.  O wait I just did
The following user(s) said Thank You: slmjim+Z1BEBE, asphalt900, sf4t7, Wookie58
  • asphalt900
  • asphalt900's Avatar
02 Jul 2026 12:49
#925447
Silly Bird ha.
