- Thank you received: 1
displacement
- RedneckSamurai
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
- RetroRiceRocketRider
- Thank you received: 29
- RedneckSamurai
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
- wireman
- Visitor
- APE Jay
- Visitor
thats what I was thinking, but if its even across all four and not 8.5:1 it would suggest if has been modified?
You can not tell compression ratio by doing a compression test. Compression test only measures cylinder pressure.
Compression ratio is a mathematical equation involving cylinder displacement and combustion chamber volume.
Jay
- RedneckSamurai
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
- btchalice
- Thank you received: 7
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- RedneckSamurai
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
- steell
I discovered that it had a stock bore and carbon build up in all cylinders was causing the high readings
- nads.com
- Thank you received: 20
- APE Jay
- Visitor
Right, but if the compression is the same across all 4 and it's higher than my stock motor, wouldn't it suggest it has been modified?
Not necessarily. If a motor had aftermarket pistons with 10.25:1, but also had longer duration cams which will bleed off cylinder pressure, you might get it to only pump what a stocker does.
On the other hand, some one who is playing around with cam timing on a stock motor, and spread the overlap out, which can cause cylinder pressure to raise even though the motor is stock.
One has to really measure and examine components to see if the engine has been modified.
Jay
Post edited by: APE Jay, at: 2006/07/16 21:15
