1000J Head Gasket not Fit
  • MJinCO
  • MJinCO's Avatar Topic Author
03 May 2026 14:03 - 03 May 2026 14:29
#923615
Reassembling my 1000J with 72mm MTC pistons.  I bought a Cometic 2 piece composite head gasket  for the 72mm and it doesn't fit.  The 2 interior(next to chain) bolt cutouts do not are not as big enough and interfere with the APE studs.  I tried the gaskets in the Vesrah gasket kit and they don't fit either.  Is it normal to have to trim them out?
Could someone also confirm that their are no pins between the cylinder block an the head.
Last edit: 03 May 2026 14:29 by MJinCO.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: 1000J Head Gasket not Fit
03 May 2026 19:20 - 03 May 2026 19:29
#923623
Yes, and yes.
Those fiber head gaskets need to fit snugly between the studs...and over the locator dowel/pin at the ends of the block.
I found a round file useful to shape each stud notch...carefully, because the gaskets have a metalic mesh core that is difficult to cut, and is easily distorted.
1982 KZ1100-A2/1170cc sleeper 😀
Last edit: 03 May 2026 19:29 by daveo.
  • MJinCO
04 May 2026 06:28
#923632
Found the locating pins.  Head gasket fit is interesting,  I'm planning to but in the oil corner O rings dry or just  dab of sealant to locate it.  JoesPP did my piston fitting and he likes 1184 everywhere, but if too much is put on it could easily impede the oil flow.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
04 May 2026 15:16
#923654
No sealant worked well, based on the recommendation of one, Jeff Saunders/Z1E...some years back.
Check that the gaskets don't crowd the center O-ring, pressing it toward the chain tunnel...had to sand/file that gasket edge a small amount to clear.
  • MJinCO
07 May 2026 17:49
#923768
Thanks for help.  Done and worked well.  I used some Hylomar on the middle O ring and just enough 1184 to fix the corner O rings in position.  Applied with a tooth pick,  I find it strange the Cometic makes the gaskets that way or were the made for some earlier version of the motor?
