cltch spring bolts
- kawastrtfgtr
cltch spring bolts
18 Mar 2026 08:55
hi. when thighten the clutch spring bolts . is it normal tighten and bolts spins but hols the plate?
Re: cltch spring bolts
18 Mar 2026 09:04Can you clarify what you mean please ?hi. when thighten the clutch spring bolts . is it normal tighten and bolts spins but hols the plate?
The following user(s) said Thank You: kawastrtfgtr
- zed1015
18 Mar 2026 12:21
If you mean the clutch pressure plate spring bolts they should tighten and not continue to turn once nipped up. .
If any continue to turn then the aluminium threads are likely to have stripped in the clutch hub.
- kawastrtfgtr
19 Mar 2026 05:13
yes. you are right. i purchased clutch hub. thank you
