Which Side Faces Up?
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
17 Mar 2026 20:10
#922305
1000/1100-J cam cover gasket:
or
Graphite coated?
1982 KZ1100-A2/1170 sleeper 😀
  • TexasKZ
  • TexasKZ's Avatar
Re: Which Side Faces Up?
17 Mar 2026 20:18
#922307
Yes.
  • daveo
  • Premium Member
  • Premium Member
17 Mar 2026 23:01
#922310
Perhaps installed with smooth side A down, residue left when removed will clean from the head surface easier.
I'm not sure what the install process for this gasket type is...
  • zed1015
  • zed1015's Avatar
18 Mar 2026 01:44
#922312
They usually go either way but in this case i'd put the "B" side down towards the head judging by the markings it has which may be sealer.
This is the first time i've seen that, what make is it ?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
18 Mar 2026 02:18
#922313
Dave am I right in thinking that side "B" has a raised ridge ? (not easy to tell in the pics with old eyes :)) if so personally I would think side "A" sits against the head with the ridged side taking up any distortion in the cover (only my opinion ?)
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
18 Mar 2026 04:10 - 18 Mar 2026 04:11
#922315
   The edges of the 'half moon' cam end plugs in heads don't always sit perfect;y flush with the gasket surface of the head.  We'd suggest side B face the head. so that what looks like the pairs of short sealant bead be aligned with the two edges of each cam end plug where they meet the head to seal if there's slight variation from flush.
   We've never seen a valve cover gasket with apparent sealant beads like that.   +1 on ZED1015's question; what brand is it?
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 18 Mar 2026 04:11 by slmjim+Z1BEBE.
  • daveo
  • Premium Member
  • Premium Member
18 Mar 2026 09:39 - 18 Mar 2026 10:00
#922332
The gasket is OEM Kawasaki 11061-1121, 11060-1691, and possibly others.
I believe it was offered specifically for KZ1000-J Police motors...but please don't quote me on that.
The raised surface is present at the four end-plug locations on both sides:
I wonder if this gasket type should be installed dry?
Sealant application might actually impede it's performance.
Last edit: 18 Mar 2026 10:00 by daveo.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
18 Mar 2026 10:16
#922333
If the surfaces are good I wouldn't expect to need sealant (unless the manual calls for it)
  • daveo
  • Premium Member
  • Premium Member
18 Mar 2026 10:45 - 18 Mar 2026 16:22
#922334
If the raised feature is a heat-activated bond material, then a heat gun should produce an improved gasket seal at the end-plug locations.
Installed it dry, and will see how that works.
The end plugs are solid aluminum pieces previously installed with sealant as recommended.
Each plug is firmly seated slightly below the head surface, and the cover bolts were torqued to 87 inch pounds.
Last edit: 18 Mar 2026 16:22 by daveo.
  • daveo
  • Premium Member
  • Premium Member
28 Mar 2026 11:00 - 28 Mar 2026 11:26
#922596
The first oil change and valve lash adjustment have been done after accumulating 300+ miles over several short riding sessions.
Perhaps the seal of this gasket will outperform others typically cut from compressed sheet material, which one may presume require less effort to manufacture.
After putting down a couple hundred more miles, I feel pretty good about the choice as there is no evidence of leaks whatsoever.
Actually, she runs better now than all of last year, though I did nothing different reassembling her this time.
Seems there may be no limit with these KZ motors, as long as
properly manufactured  quality components are carefully installed, and not babied too much.
Oh, wait...I installed different motor oil, as Ed insisted suggested...
Thanks Ed
Last edit: 28 Mar 2026 11:26 by daveo.
The following user(s) said Thank You: asphalt900, Wookie58
  • asphalt900
  • asphalt900's Avatar
29 Mar 2026 04:48
#922603
Good to know Ed! Wish they made those for the Z1 and early thru 1980 KZ1000's. If you've ever purchased the "newest" style stator engine cover gasket, they are also grey coated like your cam cover gasket. They are a metal core and like to magnetically stick to the rotor upon assembly but work Great, much better then the paper ones. Same as yours too, dry assembled. Only a smidge of sealant around the stator grommet. Great Job Ed! You realize one it's out of the dining room it's going to start to get dirty ha.
