Recommend sealant for Z1 sight glass, please.
- slmjim+Z1BEBE
11 Mar 2026 09:26
A NOS, bare-aluminum aftermarket finned clutch cover, sans sight glass, came to us not long ago. A Z1-B of ours came with the same aftermarket, finned points, dyno, starter and teardrop clutch adjuster covers already installed when we bought it. None are chromed. The NOS finned clutch cover will complete the set, something we've been after for a long time.
We've never installed a sight glass from scratch. What sealant would be recommended?
TIA.
Good Ridin'
slmjim & Z1BEBE
TIA.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- MFP-Joe
Re: Recommend sealant for Z1 sight glass, please.
11 Mar 2026 09:47
I've installed many such sight glasses:
Sometimes with a very thin layer of RTV Black all around, but many also "dry" without sealant... I've never experienced a leak! ( Same process like installing a shaft seal!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Z1000 A2 1977
Greetings, Joe
- Cra-z1
11 Mar 2026 10:46
I use Honda bond or equivalent.
The following user(s) said Thank You: slmjim+Z1BEBE
- sf4t7
11 Mar 2026 11:03
I've never used sealant, they seem to fit tight enough. But a thin layer of sealant can't hurt.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- zed1015
11 Mar 2026 12:39
They don't need any sealant.
They fit like an oil seal so just wipe the outside with a bit of lube for ease of fitment.
The following user(s) said Thank You: StreetfighterKz, slmjim+Z1BEBE
- slmjim+Z1BEBE
12 Mar 2026 09:15
Thanks for the replies everyone.
Main reason we asked is because it appears that Mama Kaw used some kind of white, hardening sealant on them. It would be a Bad Day if one popped out while Ridin'.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- ckahleer
12 Mar 2026 10:09
The replacement clutch and brake reservoir sight glasses for my V65 Magna were simply glass disks with no seals. The vender's instructions recommended sealing them in place using clear silicone sealant. I never had a problem with leaks after installing them.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- Kelly E
12 Mar 2026 10:27
All the sight glasses we've replaced are a tight press fit with an o-ring that goes in first. We've done Suzuki, Honda and Kawasaki brake and clutch master cylinders. We bought a bag of ten replacements and used the same ones on all the different makes.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
- bry195
14 Mar 2026 19:23
I didnt use sealant on the sight glass. Just installed it with some silicone grease. I thought about a sealant but I thought about the smell of fuel I used to get from the oil. I fixed the leaks in the carbs but i did find a sealant that holds up to fuel. Ive tried allot of them and so I didnt have allot of faith. Permatex 85420 doesnt harden completely but it has sealed many things that leak gas.
