Engine fitting
  • Stusco
  • Stusco's Avatar Topic Author
Engine fitting
07 Mar 2026 01:09
#922008
Whats the easiest way to fit my engine back in the frame ,i was thinking of lying it on its side on some blocks and fitting the frame over it and bolting it in .what do you do ?
GPZ1100a1
  • zed1015
  • zed1015's Avatar
Re: Engine fitting
07 Mar 2026 02:00
#922009
laying the frame over the engine is the most common method when fitting in a mostly bare frame.
The following user(s) said Thank You: Stusco
  • Bloobaba
  • Bloobaba's Avatar
Re: Engine fitting
07 Mar 2026 06:16
#922011
You just take the engine and place it in the frame, and with your other hand, insert the fasteners while sipping a beer through a straw.
More seriously, some friends lay the engine on its side and then place the frame on top. Once it's secured, you just straighten the whole thing.
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
Re: Engine fitting
07 Mar 2026 16:43
#922023
I always install the center stand before setting the frame over the motor. Then after you stand it up you just need something to prop up the front of the frame and you're set.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
