Points and condensers
  • Saioro
  • Saioro's Avatar Topic Author
12 Feb 2026 07:03
#921425
Hi there need some help on points & condensers, someone can give me some help (1975 Z1 B)
thanks
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Points and condensers
12 Feb 2026 07:54
#921427
DO NOT waste money on repro chinese shit. Condensors last 6 months if your lucky and points faces dont sit square and the heels are all over the place size wise.
I would always clean and run the original oem japanese stuff if i couldnt find nos.
failing that run a dyna electronic plate. You dont need dyna coils and leads it'll run fine on oem coils and leads.
The following user(s) said Thank You: MFP-Joe, sf4t7, Wookie58
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
13 Feb 2026 16:55
#921468
Gotta agree with Warren3200gt re: don't try running chinesium ignition parts.
If condensers are sized correctly electrically to limit material transfer, Z1 points can last nearly indefinitely with a little dressing using a points file.  Condensers are easy to test with most DMM's.
We've never run a Dyna plate on any of our Z1's.  slmjim has run points on his Z1-A since he bought it new.  All of our other Z1's have points.
We'll help if we can.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
