Z1 Kickstart Cover
  • JT-NZ
  • JT-NZ's Avatar Topic Author
Z1 Kickstart Cover
24 Jan 2026 19:38
#920923
Starting to work on my '73 Z1 900 engine and have found that the cover for the kickstart shaft is broken around one screw mount.
Looking at those on Ebay, it appears that they are common to all Z1's and some 1000's, so can someone verify this please ?
  • TexasKZ
  • TexasKZ's Avatar
Re: Z1 Kickstart Cover
24 Jan 2026 21:35
#920924
Same part number 1973 - 1981 900 and 1000.
www.partzilla.com/product/kawasaki/14032...72d6a81789c9d544cf88
The following user(s) said Thank You: JT-NZ
  • hardrockminer
  • hardrockminer's Avatar
25 Jan 2026 04:06
#920926
They are essentially the same from 73 to at least 80 but if you're a stickler for correctness the Z1 was black and had Made in Japan & an "S-1" casting on the inside and the boss inside.  Later ones had a different casting system.
The following user(s) said Thank You: Mr. E
  • JT-NZ
25 Jan 2026 23:12
#920958
Ok, thank you very much guys.
