ID me
- Mr. E
ID me
27 Dec 2025 23:18
1977 kz1000 - the Rooster, 1981 KZ750 Chopper, 1975 KZ400 , 1984 GPZ750
- Mr. E
Re: ID me
01 Jan 2026 08:32
Any one recognize the maker of the clutch?
experimental lock up im assuming but would love to find out more.
Re: ID me
01 Jan 2026 08:53Could be an early MTC unit ref the below link to ARTAny one recognize the maker of the clutch?
The following user(s) said Thank You: Mr. E
- Mr. E
Re: ID me
02 Jan 2026 15:31
I reached out to MTC, Hope to hear back - I will update with what I find out!
- Mr. E
Re: ID me
29 Jan 2026 12:59
MTC said they had nothing to do with it -
I was referred to FBG to see if he knows what wass up , but I did see another full ART clutch on a bike for sale on FB. In talking with the seller he was able to tell me ART stood for American Racing Tech but was unable to find any more information either-
The search continues.....
- urankjj
Re: ID me
29 Jan 2026 15:38
Not to add to the mystery but mine is a MRE lock up on my kz-1000 A1. It came with a spacer plate between the cases and the clutch cover. I haven't had it opened since then but I think it had more counter weights than the one pictured.
- zed1015
Re: ID me
29 Jan 2026 15:52Yes! The MRE and MTC lockup's have 5 .Not to add to the mystery but mine is a MRE lock up on my kz-1000 A1. It came with a spacer plate between the cases and the clutch cover. I haven't had it opened since then but I think it had more counter weights than the one pictured.
One for each clutch spring which is the common configuration.
Re: ID me
29 Jan 2026 16:30Karata has 5 as wellYes! The MRE and MTC lockup's have 5 .Not to add to the mystery but mine is a MRE lock up on my kz-1000 A1. It came with a spacer plate between the cases and the clutch cover. I haven't had it opened since then but I think it had more counter weights than the one pictured.
- Injected
Re: ID me
30 Jan 2026 06:07 - 30 Jan 2026 07:18
All lockup kits I have seen are just covers and plates with pressure arms, this looks like a complete modified hub probably for the spring configuration.
Like others have mentioned not sure why they have chosen to use 3 springs/arms, a bit unusual.
If I want less static pressure in a lockup you can run only 4 springs if needed, its not going to effect the way it works. The way this is configured your kind of stuck for adjustment unless you alter the spring stack.
1978 KZ650B2 modified project
Last edit: 30 Jan 2026 07:18 by Injected. Reason: more info
Re: ID me
31 Jan 2026 07:56
It's got be wondering what the clutch cover looked like
OR could it be a dry clutch setup
- urankjj
Re: ID me
16 Feb 2026 15:30 - 17 Feb 2026 15:52
Finally found a pic of the MRE spacer. [attachment=181907]6438-3864%3ADCIM%2F103NIKON%2FDSCN0455-1.JPG
Last edit: 17 Feb 2026 15:52 by urankjj.
