Piston Rings
- Brian_antrican
Piston Rings
02 Nov 2025 16:54
I'm waiting for a full gasket set, since the weather here's pretty lousy lately... gonna replace most of the gaskets on the kz440, and figured i'd do the rings as well. anyone know a good place to get a set? i tried z1enterprises, and they had rings for the larger kwakas, but not the 440. hmmm.
Re: Piston Rings
02 Nov 2025 17:49 - 02 Nov 2025 17:50
The factory rings seem to be available.
www.partzilla.com/catalog/kawasaki/motor...linder-pistons-80-b1
Last edit: 02 Nov 2025 17:50 by TexasKZ.
- sf4t7
Re: Piston Rings
02 Nov 2025 18:43 - 02 Nov 2025 18:45
IMD Pistons have rings for almost any motorcycle. Unfortunately, they're located in England. Maybe not a problem for you in France.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 02 Nov 2025 18:45 by sf4t7.
The following user(s) said Thank You: Warren3200gt, Wookie58
Re: Piston Rings
03 Nov 2025 04:50 - 03 Nov 2025 04:50
Last edit: 03 Nov 2025 04:50 by TexasKZ.
- Bloobaba
Re: Piston Rings
03 Nov 2025 09:18
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
