Red cherry exhuast!
- Balut
Red cherry exhuast!
13 Oct 2025 12:45 - 13 Oct 2025 12:46
Working on my 1978 kz650, I noticed that the inside of my exhaust super red inside. Its was running for a good 4-5min that I noticed the inside was getting super hot. I cant tell from the outside of the header because I have an exhaust wrap. It has a welded ducati exhaust
Last edit: 13 Oct 2025 12:46 by Balut.
Re: Red cherry exhuast!
13 Oct 2025 13:08
The wrap will retain heat in the exhaust but that still seems excessive ?
- Balut
13 Oct 2025 13:22
I wish I took a picture, it was GLOWING! Reading up saying bike might be running lean? Hopefully a nice carb clean will fix it
13 Oct 2025 14:01
I'm not sure if this applies, but NEVER let your bike run, parked, for more than a couple of minutes, unless you have air blowing over the engine. Not only does the exhaust overheat, the engine proper does also.
The following user(s) said Thank You: Injected, MFP-Joe, Warren3200gt, Wookie58, Balut
- Balut
14 Oct 2025 09:09
Thank you! I was just trying to adjust the rpm idle and play with the choke. do you think its safe to plug a fan right in front of it?
- Injected
14 Oct 2025 09:27Its safe as long as your feet are not in 1/2" of water.Thank you! I was just trying to adjust the rpm idle and play with the choke. do you think its safe to plug a fan right in front of it?
1978 KZ650B2 modified project
