Which way is correct
  • lovethemkzs
  • lovethemkzs's Avatar Topic Author
07 Oct 2025 09:07 - 08 Oct 2025 06:09
#917925
    I believe I might have installed these upside down when I put my valve cover gaskets on because it seems like I'm blowing oil from the front by the rpm sensor and I think I put them upside down can somebody correct me on which way is up LOL
Last edit: 08 Oct 2025 06:09 by Street Fighter LTD.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Which way is correct
07 Oct 2025 09:16
#917926
These are an air bleed into the exhaust so there shouldn't be oil in there regardless
  • lovethemkzs
07 Oct 2025 09:56
#917927
Well I can't read all them post you have to go through and figure out what's wrong and be simpler if you just told me why I got oil there I can see the ports from the head goes into the valve body where the reeds are and supposed to exhaust the gas outside the tube into the air box and reburned if I'm correct
 this bike evidently was rebuilt down in Allentown Pennsylvania by somebody and I come across a lot of s*** work as far as that's one problem now I'm seeing another
at top dead center the cam marks should be opposite directly of each other and they're not it looks like they put one of the cam gears 180 out because I'm getting top dead center the left cam at 12:00 and the right cam at 4:00 when they should both be at 9:00 and 3:00 if I'm correct
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
08 Oct 2025 05:48
#917967
lovethemkzs post=917927 userid=79689at top dead center the cam marks should be opposite directly of each other and they're not it looks like they put one of the cam gears 180 out because I'm getting top dead center the left cam at 12:00 and the right cam at 4:00 when they should both be at 9:00 and 3:00 if I'm correct
Not understanding.  Z1/KZ1K motors are interference-design motors.  If cams are mistimed, valves & pistons interfere with each other.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
08 Oct 2025 06:11
#917968
Please take a picture of te cams showing  what you said is the condition .
Verify TDC
  • Kofla
  • Kofla's Avatar
08 Oct 2025 08:17
#917975
This is the correct way.
1978 Kawasaki KZ1000 LTD
2010 Kawasaki Ninja ZX-14
  • moizeau
  • moizeau's Avatar
08 Oct 2025 08:21 - 08 Oct 2025 08:21
#917976
Or jusr delete it all and plug the airbox feed. Just did my Zeph11
Last edit: 08 Oct 2025 08:21 by moizeau.
The following user(s) said Thank You: Mr. E, Wookie58
  • 82KZ305Belt
  • 82KZ305Belt's Avatar
08 Oct 2025 08:56
#917977
Great post by Patton showed me how to do the deletion.
kzrider.com/forum/2-engine/603703-air-suction-system#740223
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 Oct 2025 08:59
#917978
Oil can only get into that chamber either from a leaking cam cover gasket around the port into the head of if the exhaust port is oiling because of a leaking valve stem seal etc
  • Nessism
  • Nessism's Avatar
  • TexasKZ
  • TexasKZ's Avatar
08 Oct 2025 22:10 - 08 Oct 2025 22:13
#917991
First pic looks correct. The air flow is from the air filter box to the exhaust ports, so the reed valves should open downward toward the exhaust ports.
The point of the system is to introduce clean air into the exhaust ports thus diluting the pollutants in the exhaust stream to keep the government folk happy with the gasses exiting the exhaust pipes.
Last edit: 08 Oct 2025 22:13 by TexasKZ.
  • moizeau
  • moizeau's Avatar
09 Oct 2025 09:14
#918001
Did the Zeph 'cause after doing valve clearances I tested the clean air vacuum solenoid and it was permenantly open. This is '95 bike so not 'that' old. It also frees up some space under the tank which is restricted to say the least which is why the cam cover is in 2 halves. Would have capped at the head but with the engine in, not a chance.
