It's like a box of chocolates. 50 year old motorcycle. multiple PO's
  • ckahleer
  • ckahleer's Avatar Topic Author
22 Sep 2025 15:02
#917509
I melted the piston in my TC185. I was on the highway, holding it at full throttle for about 5 minutes.
When I disassembled the top end, there was no head gasket. Did a PO forget to put it in? Was it intentional, trying to increase compression?
How much compression increase would this provide? Could this have contributed to my melted piston?
97 ZL600
94 VF750c
94 KE100
82 KZ305
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: It's like a box of chocolates. 50 year old motorcycle. multiple PO's
22 Sep 2025 15:27 - 22 Sep 2025 15:32
#917512
This used to be “a thing” back in the day with 2 strokes (lap the head to the barrel with valve grinding paste and delete the gasket
Also after prolonged WOT you need to “blip” the throttle when slowing (shutting the throttle means no 2 stroke oil being drawn in and overheating the piston)
Last edit: 22 Sep 2025 15:32 by Wookie58.
  • Injected
  • Injected's Avatar
22 Sep 2025 16:40
#917513
ckahleer post=917509 userid=54928I melted the piston in my TC185. I was on the highway, holding it at full throttle for about 5 minutes.
Deleting the head gasket may have put the compression up by 1 point and since its low compression anyways it probably did not contribute to that hole.
For example, a .040" gasket on a 70mm piston gives about a -1.5:1 compression difference. It also really depends on the piston dome and combustion chamber volumes, there are online calculators to figure this out.
1978 KZ650B2 modified project
