Slow warm up ?
- Kaw-boy 900
- Let the Good ''Old'' Time Roll !
Slow warm up ?
19 Sep 2025 14:53 - 19 Sep 2025 15:08
My KZ 900 start with a little bit of choke, and fire right away. It's take a while before it warm up. Then, a minute or two with some choke it's good to go !
I used to get no warm up period on all my others bikes, cars or trucks more than few sec. !
I know my bike is 50 YO but I dont take this for excuse ...LOL
Kawasaki and other bike ownend.
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Harley Softail 2009 For sale !
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 19 Sep 2025 15:08 by Kaw-boy 900.
Re: Slow warm up ?
19 Sep 2025 15:21
Sounds normal, other than the part where you say it warmed faster before.
How much is the bike getting ridden these days? If not much, that could explain the reason. Maybe some fuel system cleaner in the next couple tanks of gas?
The following user(s) said Thank You: Kaw-boy 900
Re: Slow warm up ?
19 Sep 2025 16:00
The following user(s) said Thank You: sf4t7, Kaw-boy 900
- KZQ
- Administrator
Re: Slow warm up ?
19 Sep 2025 19:30
I also have a KZ900. You've pretty much described it's start up routine. My KZ1100 demands even more time to be ready. If I cut it short, I'm risking it stumbling when I pull away from a stop.
Bill/KZQ
Bill/KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- slmjim+Z1BEBE
Re: Slow warm up ?
20 Sep 2025 05:34 - 20 Sep 2025 05:38
All of our stock Z1's require varying amounts of richer mix added by the enricher circuit (Z1's, often referred to as 'choke') and both of our stock CB750 Nighthawks (true chokes) to pull from a dead stop smoothly when cold for the first few miles. As the motor warms and, just as importantly, as the carbs/intake tracts themselves get hot, the choke/enricher can be can be moved to OFF. Hot carbs & intakes vaporize fuel better than when cold.
If it runs well hot & plugs look good, suggest it be left as-is. At best, one can drive oneself nuts chasing N-th degree perfect carburation on relatively-crude 50 yr. old carbs.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 20 Sep 2025 05:38 by slmjim+Z1BEBE.
The following user(s) said Thank You: Wookie58, Kaw-boy 900
- Kaw-boy 900
Re: Slow warm up ?
20 Sep 2025 12:57 - 20 Sep 2025 13:02You are right ! Sometime my bike sleep in the garage for 2 - 3 weeks... like when I wrote this post. Today was a shorter warm up as I rode it the day before.Sounds normal, other than the part where you say it warmed faster before.
''the part where you say it warmed faster before'' ...I mean other vehicles.
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 20 Sep 2025 13:02 by Kaw-boy 900.
- JR
Re: Slow warm up ?
20 Sep 2025 15:41
Modern motorcycles cars etc are almost all fuel injected controlled by an ECU working on feedback from sensors. No carbs and no manual choke or enricher. I'm old enough to have had a car with a carb and choke and startup was same as the bike.
Your couple of minutes to warm up is pretty good. Normal. Part of the fun of an old machine
The following user(s) said Thank You: sf4t7, Wookie58, Kaw-boy 900
- Kaw-boy 900
Re: Slow warm up ?
23 Sep 2025 14:07 - 23 Sep 2025 14:08I'm older and did'nt found a fix for this ! It's getting worst evrey years. Is there a recall or something we can do ??
At least, when I ride, the symptons disapear and no body notice it with my full face on ...
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 23 Sep 2025 14:08 by Kaw-boy 900.
Re: Slow warm up ?
24 Sep 2025 01:34If you find a "fountain of youth" let me know, in the interim strong coffee and refusing to "roll over" will have to doI'm older and did'nt found a fix for this ! It's getting worst evrey years. Is there a recall or something we can do ??
