One cylinder not firing
- danam
21 Aug 2025 12:24 - 21 Aug 2025 12:24
Hello, just starting my restoration for the very first time and to my amazement it started right up. Carbs did not overflow or leak. I immediately went to work with synchronizing the carbs and they are all consistent. Some things I noticed:
- cylinders 2 &3: when I removed the vacuum plugs in the carb manifold, gas came out.
- Cylinder 4 doesn't fire. I have a good spark on all cylinders. Compression is about 165 across all 4. I just shimmed all the valves to spec. When I arm it up and rev it higher it seems to start firing, but definite doesn't fire on idle. Any suggestions?
Last edit: 21 Aug 2025 12:24 by danam.
- Warren3200gt
Re: One cylinder not firing
21 Aug 2025 12:57 - 21 Aug 2025 12:58
Pilot circuit is blocked on that carb/cylinder.
Pilot circuit solely supply's fuel upto approx 3k rpm. Once above that the needle jet circuit joins in and then above 6k the main jet circuit joins in.
Last edit: 21 Aug 2025 12:58 by Warren3200gt.
- danam
21 Aug 2025 13:13 - 21 Aug 2025 13:14
ah yes. thank you. The air mixture screw was not adjusted correctly. Thanks!
Do you know why I would find gas coming out of the vacuum ports?
Last edit: 21 Aug 2025 13:14 by danam.
21 Aug 2025 15:02Possibly worn choke plungers ? - Zed1015 is your man for thoseah yes. thank you. The air mixture screw was not adjusted correctly. Thanks!
- asphalt900
22 Aug 2025 02:41
All these intake manifolds with down facing port caps will develop a petrol puddle in them. That's not a big deal. You still using the 2170 Z1B carbs shown earlier?
