Crunchy engine sounds
  • Bunny Love
  • Bunny Love's Avatar Topic Author
18 Aug 2025 08:40
#916179
Hello!
When my engine is idling in neutral it makes this kind of crunchy sound. When in gear or going down the road it runs smoothly and seems okay. I'm not sure what might be making the sound or how to fix it but it causes concern. Any advice on this would be greatly appreciated.
1980 KZ650
Lafayette, IN
  • kimchella
  • kimchella's Avatar
Re: Crunchy engine sounds
21 Aug 2025 10:29
#916293
Hi, when ticking over in neutral does it stop when you pull in the clutch ?
KZ650B1 frame number 225
New Zealand
  • Nessism
  • Nessism's Avatar
21 Aug 2025 10:57
#916294
Most likely normal primary chain and clutch lash chatter.
  • riturbo
  • riturbo's Avatar
21 Aug 2025 11:51
#916295
  Syncing the carbs might help .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Warren3200gt
  • Warren3200gt's Avatar
21 Aug 2025 13:32 - 21 Aug 2025 15:02
#916299
On your video it sounds like your idle/tickover is set way too low. Should be 1000-1200rpm. The lower the tickover the worse the effects and noise from worn primary chain lash, worn clutch damper rubbers, out of sync carbs.
What is your tickover set to?
Last edit: 21 Aug 2025 15:02 by Warren3200gt.
  • Bunny Love
22 Aug 2025 06:42
#916323
It doesn't that I have noticed.
1980 KZ650
Lafayette, IN
  • Bunny Love
22 Aug 2025 06:44
#916324
I'm not sure. I am very new to maintaining a motorcycle and working on them. I know it runs rich and backfires when I downshift, and it also idles around 1000 rpm. I haven't been doing this long enough to look into how to adjust it yet.
1980 KZ650
Lafayette, IN
  • Bunny Love
22 Aug 2025 06:45
#916325
I'll have to look into how to do this.
1980 KZ650
Lafayette, IN
  • asphalt900
  • asphalt900's Avatar
22 Aug 2025 08:36
#916327
Just when You were concerned about a New paint scheme!! Sounds like an old single cylinder farm thrasher. Yes, like Warren PLEASE turn-up the idle. You'll wreck that engine if you leave it that way. Just like those Harley and Chevy fellas do, setting idle soo low it destroys the Crankshaft journals. But it, to them, sounds cool?? Might i mention valve lash checking, another whole story in itself though.
The following user(s) said Thank You: MFP-Joe, Warren3200gt, Bunny Love
  • kevski
  • kevski's Avatar
31 Aug 2025 05:18
#916604
That idle speed is way too low, you sure it's not a hardly?
  • TexasKZ
  • TexasKZ's Avatar
31 Aug 2025 06:38 - 31 Aug 2025 06:39
#916607
I don't know which model you have and the video will not play for me, but there is a decent chance that there is a copy of the factory service manual for your bike in the Filebase here at KZR. The manual will describe the proper methods.
The only unusual tool you will need is the synchronizer. There are four basic types on the market, vacuum gauge, liquid filled, metal rod and digital.. It seems that every person who adjusts their own carbs is irrationally in favor of one style over the rest. I am currently using a Carbtune (metal rod style) and am well pleased with the results. As with any tool, it is best to stay away from the really cheap ones.
Last edit: 31 Aug 2025 06:39 by TexasKZ.
  • kevski
  • kevski's Avatar
31 Aug 2025 08:53
#916616
It's a 650 c3, so probably out of sync carbs, and clutch basket rubbers shrunk and rock hard.
The following user(s) said Thank You: Warren3200gt
