Cold compression test
  • Maxbou92
  • Maxbou92's Avatar Topic Author
02 Aug 2025 17:44 - 02 Aug 2025 17:44
#915440
What are you thinking about my compression test?!  1800 miles after rebuilt.
  Do theses numbers could be better after more miles or they are what they’re supposed to be ?1 : 1522 : 1613 : 163 4 : 152
Kz750e 1980
Last edit: 02 Aug 2025 17:44 by Maxbou92.
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Cold compression test
02 Aug 2025 21:57 - 02 Aug 2025 22:41
#915443
1 : 152
2 : 161
3 : 163
4 : 152
Cold, they are good. Difference between hot and cold readings is about 15-20 psi extra.
Book readings from the fsm for a 650 is 165-185psi hot. A 750 E is around 140psi hot (I think).
Last edit: 02 Aug 2025 22:41 by Warren3200gt.
  • Maxbou92
03 Aug 2025 03:03
#915451
Thank youu 😌
Kz750e 1980
