Valve clearances question...
  • Biquetoast
  • Biquetoast's Avatar Topic Author
  • King Jeremy The Wicked
15 Jul 2006 14:46
#62191
Here's what I have for valve clearance on my 750 twin:
Left exhaust:.102mm Right exhaust:.076mm
Left intake:.064mm Right intake:.076mm
What do you think?
Should I re-shim (one or any/more)?
They're all pretty much in range according to my manual (.05~.10mm).
My big question: Do you think the left side is affected by a large clearance for exhaust but tight for intake?
Thanks in advance for tips, advice, etc...
Post edited by: Biquetoast, at: 2006/07/16 10:48
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • steell
  • steell's Avatar
Re: Valve clearances on my 750 Twin...
15 Jul 2006 14:57
#62193
I think the clearances you have listed are fine, and there will be no noticable difference power wise by changing any of them.
Post edited by: steell, at: 2006/07/15 17:58
  • Biquetoast
15 Jul 2006 15:06
#62194
Interesting, thanks.
I should mention that the reason I checked them in the first place (besides the fact that I never had before), was that they make no noise whatsoever (unlike my other twin), and the engine idles less smoothly after about 45 minutes of my commute or in stop-stop traffic. I thought that fit the description of tight (or no) clearance.
Hmm...
Post edited by: Biquetoast, at: 2006/07/15 18:07
kz750twins.com
  • wiredgeorge
  • wiredgeorge's Avatar
17 Jul 2006 07:02
#62561
BT: As Steve mentioned, the clearances are fine. The clearances are supposed to be checked cold and while the clearances close up some when the bike warms, the spec takes that into account.
  • donthekawguy
  • donthekawguy's Avatar
17 Jul 2006 16:52
#62728
While you have it aprt you might as well do the left exhaust. I would just to feel I got something done for the day! :P
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Biquetoast
17 Jul 2006 19:44
#62759
You know, that's where I'm at with this. I just gotta believe that I should do something about the left side, intake is a bit tight, exhaust is a bit wide...
Anyway, I ordered the shim tool from z1enterprises, and I want to see what shims are *in* there, etc., and I'll make the call then... In the meantime, I'm riding the other bike...
kz750twins.com
  • Biquetoast
Re: Valve clearances question...
19 Jul 2006 17:27
#63228
Is it wrong to post for my own benefit? ;) I'm posting so I can keep track of it...
Here are the shim sizes after checking:
Left exhaust:2.65mm Right exhaust:2.70mm
Left intake:2.45mm Right intake:2.56mm
kz750twins.com
  • Biquetoast
18 Aug 2006 07:14
#70579
I'm following up on this thread just for history's sake, in case anyone ever searches and finds this and wonders....
I changed my L-intake shim TO a 2.40, FROM a 2.45 (giving about 11ish clearance), and I know you guys are going to think I'm crazy, but it runs waaay better when warm now. It shouldn't have needed more clearance, but it sure helped.
I've been riding it for a week now. The only change I made was the shim, and then I went on a week's holiday. I came back, and I have ridden it to work all week and now, 45 minutes into the commute, it doesn't idle strangely anymore.
I kinda wonder if I somehow mis-read the clearances, though I can't imagine how I could have....
Oh well, I think I'll tear it apart again in the fall, re-measure, and just buy the next set of shims just to have... for the future... since they are getting more rare...
Oh, and just one more note to say that the $8 shim tool from Z1enterprises.com works very well, though it's requires a bit of muscle on the ones with tight clearance. The wide clearance one let me slide the tool in easily, the tight one required quite a bit of force. Not so much that it can't be done, and not so much as to make me want the expensive one...
Post edited by: Biquetoast, at: 2006/08/18 10:16
kz750twins.com
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
18 Aug 2006 07:57
#70599
Did you actually measure the shims? Were you able to clearly read the number on the shim?...I had to measure mine to be able to properly interpret the number on the shim...what I saw initially was different (faded numbers) than the actual measurement:unsure:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Biquetoast
18 Aug 2006 08:28
#70608
Nope!
Yep!
I can understand that. Mine were all number-face-down fortunately, and only one was a bit faded, but still pretty easy to read.
One was an "odd" size. The dealership told me that the 256 shim I have is an "aftermarket" shim, since Kaw only made them in increments of 005.
kz750twins.com
  • OKC_Kent
  • OKC_Kent's Avatar
18 Aug 2006 08:31
#70611
It is not uncommon to have a new mismarked shim. I got one that was 2 sizes too big, right from a clearly labeled Kawasaki package, with the wrong size etched on the shim. I think it was a 250 marked as 240
Cashion, OK
78 KZ650 B2 85,000+ miles
  • loudhvx
  • loudhvx's Avatar
18 Aug 2006 08:35
#70614
Yeah, taking those readings can take a few attempts to get it right. It's not too hard to push a thicker gauge in the gap, when the true gap is not that wide. Once I've gone through the hassle to get in there (and remove the cams on the 550) I just do them all. Then I know I don't have to mess with it for a few years.
When I do it, the worst part is cleaning the valve cover gasket. To make it easier, later, I put a thin layer of anti-sieze on the gasket. Then it comes off like new the next time. I still use a little silicone on the cam end plugs. If the cover leaks, then the anti-sieze may not be a good idea, but I've been lucky... never had a leaky cover yet.
Also, be sure to get the excess silicone out of the valve cover bolt holes. I've seen people strip the holes because there was some silicone in the hole. Obviously, the silicone won't compress much, and it's slippery, so it ends up easy to strip.
