removing baffling from stock pipes?
- tom13
15 Jul 2006 14:45 #62190
by tom13
removing baffling from stock pipes? was created by tom13
I have a 77 kz650 in the putting together stage and I'm thinking cutting and removing the baffling from the mufflers and welding them back. Does anyone see this being a problem for the motor in the future or does it need so much back pressure to operate correctly?
newbee in training
tom
newbee in training
tom
- roy-b-boy-b
- Thank you received: 103
15 Jul 2006 16:46 #62204
by roy-b-boy-b
Replied by roy-b-boy-b on topic removing baffling from stock pipes?
From my expierence it would sound like crap. If it is a good exhaust they could be worth enough to buy a header. I think it would sound like megaphones and that ain't good. Roy
- ambergrismooon
- Visitor
15 Jul 2006 16:55 #62207
by ambergrismooon
Replied by ambergrismooon on topic removing baffling from stock pipes?
I agree with Roy it would sound pretty bad and if you reduce muffler restriction you may well have to re-jet to get it dialed in again. And I certainly wouldn't do it to a stock exhaust. There really would be no easy going back if it was crappy and it's hard to find stock exhaust it could be worth an aftermarket setup to get the sound you want. But be advised you are most likely looking at some carb work. It's not hard and there are tons of info in the archive to help. But consider it all first.
- Pterosaur
- Visitor
15 Jul 2006 17:31 #62218
by Pterosaur
Replied by Pterosaur on topic removing baffling from stock pipes?
tom13 wrote:
I'm not quite sure what "...welding them back" means.
Personally, I'd think it'd sound like Peewee Herman playing a rectal kazoo - and as noted, you'd be looking at a carb re-jet and tuning to get it running right.
Post edited by: Pterosaur, at: 2006/07/15 20:32
I have a 77 kz650 in the putting together stage and I'm thinking cutting and removing the baffling from the mufflers and welding them back...tom
- wireman
- Visitor
15 Jul 2006 18:19 #62228
by wireman
Replied by wireman on topic removing baffling from stock pipes?
Pterosaur wrote:
Post edited by: wireman, at: 2006/07/15 21:23
:sick: :Pi remember pee wee get caught playing his trombone in public,i didnt realize he played the kazoo also hes a regular 1 man band!what?:S :whistle:tom13 wrote:
Personally, I'd think it'd sound like Peewee Herman playing a rectal kazoo - and as noted, you'd be looking at a carb re-jet and tuning to get it running right.<br><br>Post edited by: Pterosaur, at: 2006/07/15 20:32
- WharfRat
16 Jul 2006 01:57 #62320
by WharfRat
Kenosha,WI
1979 KZ 400B2
1979 KZ 650 B3
Replied by WharfRat on topic removing baffling from stock pipes?
:laugh: Pee-Wee took matters into his own hands.
Kenosha,WI
1979 KZ 400B2
1979 KZ 650 B3
- wireman
- Visitor
16 Jul 2006 10:30 #62381
by wireman
:sick:
