1980 KZ750E Thinnest Valve Shim Recommended
- FaultedGeologist
- The truly educated never graduate...
09 Jul 2025 19:15
Never ending project bike. I found a bent valve, ordered parts. Guide was too big so I checked the existing valve guide with the oem.valve I orded. There seems to be a sliiiight bit of play until the seal, then feels solid.
Lacling funds, we went for the build. Measuring the valve clearances, the new valve still contacts the cam with the smallest 2mm shim. I found some 1.85mm and up kit and also a 1.25mm up kit, but too small of a shim will leave the valve spring cap in contact with the cup, loosening the shims on each rpm.
1 what is the smallest shim that can be used on the 1980 KZ750E?
2 I could remove the head again and pull the valve, have it ground down, and reassemble with room to spare for future shims.
Problems:
I felt like the head bolt by chain tensioner started getting easier to turn as it should have hit spec. Stopped turning torque wrench and got the other bolt and 12 nuts to torque spec.
The aftermarket chain tensioner mount bolts feel bad and really close to turning out. It has to be removed every rebuild, and I fear those threads will be another thing to fix.
I will need to save to have a vlave shop grind the valve, but it probably needs a lapping that I skipped in hopes of it bedding in the kinda freshly machined seat.
I hear a fsssssst on rotating the crank for valve feelers. It has to be the new valve. I did not hook up the compression tester to each yet.
Thanks fam.
Problems:
Thanks fam.
Clint
1980 KZ750 LTD H4
FSMaunual: kz.bike-night.com/media/GPz750-full.pdf
Stock except for:
New chain and sprocket (530?).
Dynatek Ignition
Manual tensioner on the way.
Buy JIS screwdrivers.
1980 KZ750 LTD H4
Stock except for:
Dynatek Ignition
Re: 1980 KZ750E Thinnest Valve Shim Recommended
09 Jul 2025 19:58 - 09 Jul 2025 20:00
Kawasaki says hat a 2.00 shim is the thinnest to be used.
www.kzrider.com/filebase-alias?task=down...id=1266&catid=17&m=0
Last edit: 09 Jul 2025 20:00 by TexasKZ.
- Kaw-boy 900
- Let the Good ''Old'' Time Roll !
11 Jul 2025 15:14 - 11 Jul 2025 15:18
I had 1.5 mm shims (machined) when got my bike. The previous owner had one shim kick out or broken and replace, then sold the bike. I had to get the valves stem trimmed. Or you can get new seats for $$$
Kawasaki and other bike ownend.
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Harley Softail 2009 For sale !
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 11 Jul 2025 15:18 by Kaw-boy 900.
