Clank
  • Bcot
  • Bcot's Avatar Topic Author
Clank
03 Jul 2025 18:35 - 03 Jul 2025 22:00
#914348
Just did a top end on another kz1000 . Fired up runs great. But first 30 seconds had a loud clank noise! Or more like a knock ,, not in time with anything ,thought what the hell. Shut it off, thought never heard that before Just a  clank knock noise. Put new pistons valves and springs all new gaskets . New timing Chan and all rubber components and idler. Never had this happen. But it sounded like is was coming apart. But now It runs great has ran up to temp. Letting cool down and firing it up later. Timing is spot on and vacuum gages are spot on.. has anyone had this happen.
Last edit: 03 Jul 2025 22:00 by Bcot.
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
Re: Clank
06 Jul 2025 13:01
#914409
yes have had that happend after a total rebulid on my FJ1200 engine everything in engine was replaced  also the gearbox .only thing i did not replace was the crank and cases . Then started it up and clank clank clank clank clanketty-clank .Shut it off and was thinking ohh noo wt.... then did some inspections and could not find anything wrong. Then fired it up again  and no clanking.!!  i have now done about 30000 km and still runs great .
I think the clanking was because oil did not  distrubut fast enough . i also used assembly lube on all parts and the pistonskirts when rebuildt the engine so maybe that was a little to thick clogging up some oil passages .
The following user(s) said Thank You: sf4t7, Gdizard, Bcot
  • Bcot
Re: Clank
09 Jul 2025 21:54
#914506
We’ll update! Took the cam cover off and cam caps, found nothing wrong, no witnesses marks on anything.. valves are about 1/2 thou tighter (would expect after fresh valve job) so no bent valves. Compression is at 130 lbs all exactly the same so new rings are already starting to seat( usually new rings start at about 95-100 lbs). Nothing in the oil pan or oil. Only thing I can think is the auto chain tensioner hung for a second or a valve bucket was a little sticky. The sound really was more like snapping noise. It made it about 3 or 4 times right when it fire up and went away! Never had it happen before.
