Oil leak only on sidestand
- Lacher
13 Jun 2025 04:36 - 13 Jun 2025 04:36
Hi all,
On my kz1000j 1981 I have an oil leak coming from behind the front sprocket cover, behind the sprocket itself.
When on centre stand it doesn't leak, when on sidestand it leaks. Is this due to the output shaft seal ? The gasket behind the sprocket cover has been replaced 3 times already do I'm guessing it's the seal but I want some confirmation if possible because that seal had been replaced as well.
Thanks!
Thanks!
Last edit: 13 Jun 2025 04:36 by Lacher.
- KZQ
- Administrator
Re: Oil leak only on sidestand
13 Jun 2025 05:42Hi Lacher,Hi all,
Thanks!
Is there any chance you're dealing with lubricant flinging off the front sprocket?
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Vinsky
13 Jun 2025 07:45
Had a similar issue recently. Turns out it I had damaged the transmission cover gasket on assembly. New gasket, no drips.
Vinsky
- Lacher
13 Jun 2025 12:44
Hi Bill and Vinsky,
It's not chain lubricant, it only leaks on sidestand strangely.
I did change the transmission cover 3 times, all the times with the same gasket and some more silicone sealant. It doesn't drip more or less than before so seemed like it's something else, but I can't think of any other problem. I think I will go order a new genuine transmission cover gasket and see if it works..
13 Jun 2025 13:05
Might be he shift shaft seal.
The following user(s) said Thank You: Rolf1976_KZ900
- asphalt900
14 Jun 2025 02:53
Did it leak before all the multiple pulling of the trans cover? Does it dribble after a ride, engine heats up? Or just as mentioned all the time when on side stand? As Vinsky and Texas noted could be gasket or shift shaft seal, or both. One thing to note, have seen it multiple times. When installing the trans cover you can invert the single lip shaft seal by pushing it on during assembly. This makes the mess, pesky dribble you're explaining. When doing these engines i always use a Double-Lipped Shaft seal to replace the original Single. It's a 12X20X5 seal. I use Honda part# 91205-KF0-003. It's not metal OD like the original which makes it easier to install too.
The following user(s) said Thank You: KZQ, SWest, Lacher, Wookie58, Rolf1976_KZ900
- Lacher
14 Jun 2025 11:05
I don't remember it leaking before I changed all the gaskets including that shift shaft seal.
But you are totally right ! I can see that the oil comes from above the trans cover, not through the gasket itself so it must be that shaft seal! It's almost impossible to see, but it does leak from above.
Great tip about that Honda seal I have a Honda shop nearby I'll order it next week and hope this works ! I'll give an update when I get at it
- Lacher
19 Jun 2025 01:16
Alright so I installed a new shift seal, found a spare in the shelf so didn't order the Honda seal, and no more leaking !!
Thanks for the tips , happy that it's finally fixed 👌
- asphalt900
- danr123
15 Jul 2025 03:23
HELLO I reading this post " oil leak on sidestand "
I have this problem me to for my kz400 1978.
Make sure the oil level is ok, only 2.9 liters can be in . But sometime the oil level gauge can't be read perfectly.
I drop out the oil on the engine and I got 5 liters it's over.
I want to result this problem OIL LEAK.
I Will check, vérify the oil filter. Bye pass valve. And after the oil pump to resolve this problem.
HELLO
MY VINTAGE KAWASAKI KZ400 1978
- danr123
15 Jul 2025 04:31
now. To resolve this problem. temporaly I'm rising the engine about 2000 rpm before make off the engine
HELLO
15 Jul 2025 05:07What are you trying to achieve by this ? - cutting the engine at 2000rpm will cause it to draw fuel into the cylinder which will "wash" the bores and cause premature piston/cylinder wear !!! Your previous post suggests that the engine was "overfilled" this will cause excessive crankcase pressure and potentially push oil into the airbox. Overfilling is potentially as harmful and underfillingnow. To resolve this problem. temporaly I'm rising the engine about 2000 rpm before make off the engine
The following user(s) said Thank You: Warren3200gt
