1974 Kz 400 Clutch friction plates replacement
  • Newsman
  • Newsman's Avatar Topic Author
07 Jun 2025 04:37
#913453
Hi sorry its me again
I put the wrong oil in my 1974 Kz400 and now the clutch slips I ordered some new friction plates which said they were for a 1974 these were too wide across the face and did not leave room for the strange sort of spring shim that fits inside the circumference of the friction plates which I guess helps to disengage the plates from each other, I ordered some more but these are just the same
In the manual the clutch from 76 does not have the spring shim thing.
Has anyone rebuilt the clutch without the spring/shim?
Thanks in advance
Andre
  • H1Vindicator
  • H1Vindicator's Avatar
Re: 1974 Kz 400 Clutch friction plates replacement
07 Jun 2025 06:35
#913456
did you try cleaning the friction plates with a solvent? brake cleaner. or varsol. or whatever.
  • Newsman
07 Jun 2025 06:49
#913457
Hi Thanks for the reply I did try that but it still seemed contaminated so I thought I would try new plates
