GPz1100 Valve Cover Removal
  • ayeckley
  • ayeckley's Avatar Topic Author
05 Jun 2025 02:35
#913376
I was surprised to find that this doesn’t seem to have been asked before, and there’s no mention of it in the FSM:
When removing the valve cover on a 1984 GPz1100, do folks find that the oil cooler lines need to be disconnected first in order to be able to raise the cover high enough to slide out?  If there was just another 1/4” of clearance it wouldn’t be an issue.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: GPz1100 Valve Cover Removal
05 Jun 2025 02:48
#913377
To avoid the mess of dirty oil everywhere is it possible to release the cooler mounting bolts, would that give you the require wriggle room ?
  • ayeckley
05 Jun 2025 09:52
#913385
I don't *think* that would work because it would require twisting the oil lines in a way that I don't think they would like (based on their relatively large diameter).  I've never disconnected an oil line from a GPz cooler - would there naturally be a lot of oil in it?  I believe that (like the KZ engines) there's a check valve on the pressure side just downstream of the oil pump, but I'd think most of the oil in the cooler would drain down the return line overnight.  So, some mess for sure, but I'd rather deal with that (and replacing a couple of o-rings) than a cracked unobtanium oil hose.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
  • ayeckley
06 Jun 2025 18:33 - 06 Jun 2025 18:37
#913441
Update:
Unbolting the oil cooler didn’t really do the trick. Although the hoses were more flexible than I expected there still wasn’t enough room to snake the oil cooler out between the cylinder head cover and the frame.
I disconnected the oil cooler lines at the cooler inlet and outlet (just O-rings for seals, and still available from Kawasaki). As expected there was a small amount of oil still in the lines that had to be dealt with, but afterwards it was easy to move the lines so that they were no longer in the way. All that left was the usual dance required to slide the valve cover out (I found it easiest to exit to the right side of the bike).
Happily nothing was severely wrong inside the top end once I got access. One inlet valve clearance is <.0015” according to Mr. Blue Point feeler gauge set but that’s not shocking.
Anybody in the US have a non-smog valve cover they’d like to part with?
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
Last edit: 06 Jun 2025 18:37 by ayeckley. Reason: Added non-smog cover request.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
06 Jun 2025 19:44
#913443
Looking for a non-smog cam cover?
Feel free to send me a Private Message.
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: SWest, ayeckley, Gdizard
  • ayeckley
06 Jun 2025 21:59
#913446
PM sent, thanks!
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
