1000rx head and barrels to 900r
- shamal
23 May 2025 01:15
Hello folks, i have a 900r
I want to install barrells and head from a gpz1000rx
Is this possibile?
It Is compatibile?
The timing with my stock crankshaft Is ok?
I Need some good advices!
Is this possibile?
It Is compatibile?
1983 kz 550 h
- Bloobaba
Re: 1000rx head and barrels to 900r
23 May 2025 04:39
Hello. Installing 1000RX cylinders on a 900 is no good. The stroke isn't the same (+3mm). You have to machine a shim under the cylinder block and install it with two base gaskets. It's complicated. The cylinder head is the same for both bikes.
I have a 900. I installed all the 1000RX parts in the 900 engine cases. Be careful with the crankshaft bearing clearances, which must be perfect.
The gearbox is identical, as is the oil pump. You need to install a starter freewheel, an alternator shaft with its chain and ZRX tensioner.
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
The following user(s) said Thank You: Gdizard, Wookie58
23 May 2025 05:12
That is really interesting, the 900 and the 1000 both have a 74.00mm bore so the capacity difference must come from the stroke (swept volume) not the cylinder. Could you put a 1000 crank, rods and pistons in the stock 900 top end to get the 1000cc ?
- shamal
23 May 2025 05:12
So the head are identical and the only difference its the cilynder bore?
Many thanks yo your advices.
I would like to build a bit more Powerful engine, bit this seems too complicated.
Its a nosense of i Need to swap almost everything..
What about cams?
What about cams?
1983 kz 550 h
The following user(s) said Thank You: Bloobaba
- shamal
23 May 2025 05:14That is really interesting, the 900 and the 1000 both have a 74.00mm bore so the capacity difference must come from the stroke (swept volume) not the cylinder. Could you put a 1000 crank, rods and pistons in the stock 900 top end to get the 1000cc ?
This Is what i want to do! But if this Need to replace too many other parts i think its not so conveniente ...
1983 kz 550 h
23 May 2025 05:21
Seems to me that a 75mm Wiseco kit for the 900 would put you at 973cc against the 1000 at 997cc without the hassle
- Bloobaba
23 May 2025 10:47
No, you're making a mistake. GPZ900R = 72.5 x 55 GPZ1000RX = 74 x 58 Cylinder head, gearbox, crankcase, pumps, starter, and alternator are identical. Cylinder block, pistons, crankshaft, and clutches are different. The first 1000RXs had an alternator chain identical to the 900s = 7 plates. Then the chain became wider on all 1000, 1100, and 1200 models (9 plates). I can do a complete file, but it'll take time 😄. I'm doing the French-English translation with Google (Gueugueule as we say here).
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
23 May 2025 12:09
I must have misread something !! still thing the Wiseco kit in the stock motor is probably the best way to go
- Bloobaba
23 May 2025 12:28
Don't forget to include the balancer in the parts mix if you're using the 1000RX crankshaft. It's different from the 900's. The camshafts are identical on both machines. The 1000 Competition and RX models are the same. Only the camshafts and carburetors are different. And the gearbox output, of course. The RX engine vs. the GPZ900 is more powerful but less "pointu"( nervous ). The torque is greater, and it transforms the bike. But you lose the special character of the 900. That's all you can do without resorting to a complicated and expensive rebuild. It already costs money to rebuild an engine
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
- Bloobaba
23 May 2025 12:34post shamal = 912759 identifiant utilisateur = 46062
Et les arbres à cames ?
Indentical
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
Gpz900R 84
500 H1 73
Gpz550H1 82
Gpz550H2 83
The following user(s) said Thank You: shamal
