Ticking noise
- Aragone79
Ticking noise
22 May 2025 19:28
I’m hoping someone can put my mind to ease! I have fairly faint ticking noise that is driving me crazy! It seemed to just start one day. I’ve synced carbs, adjusted valves, adjusted manual cam chain tensioner and changed exhaust gaskets. I can’t pinpoint exactly where it is coming from either. New plugs and wires and plugs look good (no detonation). Doesn’t smoke and has great compression on all cylinders. I went for about a 100 mile ride the other day and it seemed to have stopped but if I go for shorter rides it seems like it’s still there. Bike runs great, it’s just a very annoying sound and I’m worried it might be something bad. I hope the video is good enough. Thank you!
- Injected
Re: Ticking noise
23 May 2025 07:53
I suggest you get a automotive stethoscope and start poking around on the cases/head to try and pinpoint the location of where the sound is originating.
1978 KZ650B2 modified project
The following user(s) said Thank You: Street Fighter LTD, Wookie58
- Warren3200gt
- Aragone79
Re: Ticking noise
23 May 2025 11:42
Thanks for the reply, that was actually my next plan of action. I tried using a long screw driver but haven’t found anything. Maybe the stethoscope will work better!
- Aragone79
Re: Ticking noise
23 May 2025 11:46
Thanks for the reply, maybe I need to open it up again and check everything.
Re: Ticking noise
23 May 2025 17:44
Ticking is a pain sometimes to locate
Try and determine if it is at crank ( Tach ) RPM
or at Camshaft RPM
One of the hardest to find in my past experience was a transmission bearing behind the clutch
Good Luck
or at Camshaft RPM
Good Luck
- Aragone79
- KZQ
- Administrator
Re: Ticking noise
24 May 2025 10:45 - 24 May 2025 10:45
The only ticking I could hear seemed very inconsistant. In my opinion it doesn't rise to the action needed level.
A lesson I just learned about my 1100 spectre is to leave the choke off for the first few cranks, until I see the oil pressure light go out. Then apply the choke to let it start. It's much quieter sooner.
Your situation is likely very different but it's what came to mind.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
Last edit: 24 May 2025 10:45 by KZQ.
- Aragone79
Re: Ticking noise
24 May 2025 12:27
Thanks Bill! Yes it is very inconsistent, and unfortunately my oil pressure switch does not work. Ive just been kinda just hoping it isn’t an oil pressure issue. There has been oil in camchest when I’ve opened it up though.
