gpz1100 unitrack oil level sensor
- JohnA
17 May 2025 13:32
Hello gents can anyone please tell me where the wire goes from the oil level sensor in the oil pan to unplug it on a gpz1100 A1.
Many thanks in advance John
The following user(s) said Thank You: krazee1
- michellehillier13
Re: gpz1100 unitrack oil level sensor
22 May 2025 18:42
if i remember correctly the two pin plug is behind the chain/clutch cover should run along side of the stator wires
- JohnA
- michellehillier13
- JohnA
26 May 2025 08:20
Yes the wire is just a single wire the plug is near the alternator wire behind the sprocket and clutch adjuster cover all done now thank you very much for your help.
