Z1000J Output Shaft Collar
  • Glenn_22
  • Glenn_22's Avatar Topic Author
05 May 2025 23:15
#912157
I removed the Transmission Cover housing today to replace the Clutch push rod, Gear change shaft and Output shaft oil seals and found that the collar is jammed tight on the output shaft (I can't even remove it off the shaft), I assumed the output shaft would spin inside the collar and not rotate with it (which means it's always spinning on the oil seal)
Is this right?
1981 Kawasaki Z1000J1
1983 Yamaha RZ350
1986 Yamaha TZR2501KT
1995 Yamaha TZR250SPR Sugo
2022 Husqvarna TE250i
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Z1000J Output Shaft Collar
06 May 2025 00:02 - 06 May 2025 00:42
#912158
Don't know for sure (I haven't got that far yet) but I would expect it to be tight otherwise oil would leak between the shaft and the collar. This type of seal is designed to be used on a rotating shaft so it's intended for the collar to spin in the seal
EDIT: Here is the answer from the FSM :)
Last edit: 06 May 2025 00:42 by Wookie58.
The following user(s) said Thank You: Glenn_22
  • zed1015
  • zed1015's Avatar
06 May 2025 00:59
#912159
That collar is a close sliding fit on the shaft and can be tight to remove after its been on a while due to it getting gummed up with oil etc.
It is designed to rotate within the seal and is trapped in positon between the bearing and sprocket once the sprocket nut is tightened.
The following user(s) said Thank You: Wookie58, Glenn_22
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
06 May 2025 08:32 - 06 May 2025 14:03
#912170
While you're in there:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 06 May 2025 14:03 by daveo.
  • Glenn_22
06 May 2025 15:22
#912183
Thanks guys that's answered my question.
Wish I had of spotted that oil seal before I placed my last bulk parts order...Doh
1983 Yamaha RZ350
