Bad crank?
- Formula264
Bad crank?
30 Apr 2025 10:57
Well I thought I just had a bad rod but after pulling the crank it's obviously out of phase. I suppose that would explain broken valve on #1 and bent wrist pin on #4. 81' KZ 1000 J motor, are those cranks known to twist or spin out of phase?
- Injected
Re: Bad crank?
30 Apr 2025 12:28 - 30 Apr 2025 12:33
Do you have any damage on #1 cylinder on the head? Looks like the piston came in hard contact with a valve or the head. When you say broken valve does that mean its sheared in half?
I can't attest to the J model, but all the big fours are basically the same and its not a very common issue as far as I have ever heard. Mechanical collision at high RPM is always a problem no matter what. Count your blessing that the rod did not escape the cases.
From what I have heard they can go out of phase like that if hit very hard. It also happens if you try to drag race using either a slick or a air shifter without having welded the pins.
There are more knowledgeable members on here that may be able to shed more light on your issue. I mostly deal with 650/750 engines where crank failures are never a issue.
1978 KZ650B2 modified project
Last edit: 30 Apr 2025 12:33 by Injected. Reason: sp
The following user(s) said Thank You: Formula264
Re: Bad crank?
30 Apr 2025 13:21
Definitely looks like a shopping trip is on the horizon
- DOHC
- Those Doe-Hawks really go!
Re: Bad crank?
30 Apr 2025 14:5081' KZ 1000 J motor, are those cranks known to twist or spin out of phase?
I have read reports here from knowledgeable folks who say that the early J motors did have a problem with twisting cranks.
www.kzrider.com/forum/2-engine/615717-welded-crank#846594
kzrider.com/forum/2-engine/216384-truein...ing-the-crank#216446
Also, from this 1982 Cycle World article:
issues.cycleworld.com/article/1982/2/1/w...-new-for-82-kawasaki
"There’s also been a change in crankshaft construction, with closer tolerances on the press fits, avoiding the problems the 1981 version had with cranks twisting with the first seriously-missed shift."
So it sounds like it may have been a particular issue with the 1981 J motor, which is exactly what you have.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: Injected, Nessism, daveo, Gdizard, Wookie58, Formula264
- daveo
Re: Bad crank?
30 Apr 2025 21:58
The J model crank pictured below was removed from a 84 GPZ-ZX1100, with 18mm wrist pins.
It now serves as the heart of my 82 KZ1100A Shaft road bike with a renovated 84 ZN1100B LTD engine.
I believe this crank was professionally balanced, and welded as it was reassembled with a new set of rods.
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: SWest, Gdizard
- Formula264
Re: Bad crank?
01 May 2025 09:45Definitely looks like a shopping trip is on the horizon
I am purchasing a complete 2000 J model Police crank. It looks the same as the 81' to me. Should fit ,right?
Re: Bad crank?
01 May 2025 09:49I am purchasing a complete 2000 J model Police crank. It looks the same as the 81' to me. Should fit ,right?
Did you compare the part numbers?
- Formula264
Re: Bad crank?
01 May 2025 09:51
#1 exhaust valve head was laying on top of the piston on disassembly. Very little damage to anything, I don't think it was a high rpm issue. But who knows
- Injected
Re: Bad crank?
01 May 2025 10:23I wonder if these later engines have decreased piston to valve clearance over the earlier engines?81' KZ 1000 J motor, are those cranks known to twist or spin out of phase?
I do know the '82 and later GPZ750 engines have reduced piston to valve clearance due to using a higher compression piston design over the KZ version engines. It is very easy to bend a valve on those engines but at least they have a one piece crank.
- Injected
Re: Bad crank?
01 May 2025 10:30A sheared off valve head seems like a very hard hit!#1 exhaust valve head was laying on top of the piston on disassembly. Very little damage to anything, I don't think it was a high rpm issue. But who knows
Kawasaki valves especially the exhaust side are known to be extremely tough so that is a surprise. Kawasaki parts in general are overbuilt from the factory.
The following user(s) said Thank You: sf4t7, SWest
