1974 Kz 400 Valve ajustmet plugs
  • Newsman
  • Newsman's Avatar Topic Author
21 Apr 2025 07:16
#911546
Hello does anyone have a spare Valve ajustment plug for a 1974 KZ400 I think the later ones were different, or does anyone know of a replacement from anoter bike that would fit, I think a previous owner must have been a body builder one of the ajuster plugs was so tight it broke while I was trying to undo it, the sump drain plug was also so tight I had to use a an impact wrench to undo it , the Plug I need is number 17 in the diagram
Attachment not found
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: 1974 Kz 400 Valve ajustmet plugs
22 Apr 2025 08:34
#911594
I do not have one to offer you. Partzilla indicates they have them in stock.
www.partzilla.com/product/kawasaki/92066...389daf0f0ceb19c13804
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Newsman
22 Apr 2025 08:38
#911596
Thank you thats great I will ask if they ship to the UK I have been looking on EBAY without any luck
  • gd4now
  • gd4now's Avatar
22 Apr 2025 09:15
#911597
OK, did not know you were in the UK. You might want to look here instead.
cmsnl.com/kawasaki-kz400-1974-usa-canada...15452/plug_92066066/
1977 KZ650 B1
  • Newsman
22 Apr 2025 10:56
#911599
Thank You I should have said I was in the UK, I am now wondering if the Cam/Head cover that holds the rocker arms could be changed for a later model one say from a 1978 with a more direct way of adjusting the valve clearance
  • Nerdy
  • Nerdy's Avatar
23 Apr 2025 12:19 - 23 Apr 2025 12:26
#911642
The heads from the '78 and '79 are different. The part number for their plug is 92066-1066.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: 23 Apr 2025 12:26 by Nerdy.
