73 - 80 valve cover ends
- sf4t7
25 Mar 2025 22:05
Just curious - does anyone know when Kawasaki added the half circle shapes to the ends of the valve cover to match the shape of the cam caps? The Z1's have smooth ends, not sure about KZ900's. Maybe it was changed with the first KZ1000's ? Can't tell by just looking up part nos for different years. ( I know they'll interchange, I've had both styles on my Z1 )
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- MFP-Joe
Re: 73 - 80 valve cover ends
25 Mar 2025 23:12
As far as i know,, the change in style of valve cover came with the first Z1000 / KZ1000...
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Z1000 A2 1977
Greetings, Joe
The following user(s) said Thank You: sf4t7, Rolf1976_KZ900
26 Mar 2025 03:52
I agree with Joe.
- sf4t7
26 Mar 2025 05:21
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- asphalt900
26 Mar 2025 05:23
Those are waay harder to find then the "typical" Z covers. I don't know exactly when they started during the 1977 KZ1000 production, 1977 KZ1000 was a split-year, changing subtle stuff. But..No KZ900 had them..unless one might be found on the "left-over" 1977 LTD900? Was it just a curious question or are You selling/looking?
- sf4t7
26 Mar 2025 05:41 - 26 Mar 2025 05:43
Thanks Clay. I'm just curious, I have both kinds. One early style with crappy flaking chrome from the late 70's that I took off the bike and I'll see if I can revive. (That one will probably just end up a nice dust cover for a spare head, haha) Currently I've got a clean later style on the bike, just bought a real nice early one to replace it. Didn't really need it but what the hell, I'm 70 years old and I like them better.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 26 Mar 2025 05:43 by sf4t7.
The following user(s) said Thank You: asphalt900, Wookie58, Rolf1976_KZ900
- asphalt900
26 Mar 2025 06:39
Those "chromed" ones can hide a lot of imperfections underneath, won't know till you remove it. But like me, the flakier the chrome the easier is to remove. That's how all those ex-wives of mine "released" from my shiny wallet, ha.
- Mcdroid
- Gone Kwackers
26 Mar 2025 06:42
So, I have a 1977 KZ1000A and a 1975 Z2A. The Z2 has the smooth ended cam covers while the 1977 has the raised half-circle cam cover ends. Both covers appear to be original to the motorcycles.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- sf4t7
26 Mar 2025 09:47
Yeah, the chrome on the valve cover is mostly all flaked off with the rough pitted aluminum exposed, I had it stored in a buddy's garage for a few years before retrieving it from his ex. Never knew how damp it got in there. (turns out the roof had a big hole in it) Probably would have been better off outside! Most likely that piece will end up as garage art. I replaced all the other crappy chrome pieces with good used bare aluminum ones. Definitely was worth it reviving the bike though! It's like going back in time whenever I ride it.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- MFP-Joe
26 Mar 2025 10:17
Yesss, Scotty,....i like to ride my "time-machines" always again, whenever i do it, it feels great and unbeatable !
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Z1000 A2 1977
Greetings, Joe
- slmjim+Z1BEBE
27 Mar 2025 05:17
Vapor blasting might work wonders on that early cover. The polished ends can usually be brought back with TLC by increasingly-finer wet sanding followed by jewelers rouge. If there's deeper pits in the polished areas, they probably wont be noticeable from 10 ft. at a glance.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: Rolf1976_KZ900
- sf4t7
27 Mar 2025 05:32 - 27 Mar 2025 05:33
Thanks, but it's probably too weathered and pitted to put much effort into. Also, it was part of an "exchange" chrome kit so it wasn't the original on the bike. I've replaced all the chrome items from the kit with good used plain aluminum ones.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 27 Mar 2025 05:33 by sf4t7.
The following user(s) said Thank You: SWest, Rolf1976_KZ900
