Oil leak
  • Andyp62
  • Andyp62's Avatar Topic Author
Oil leak
18 Mar 2025 01:42
#910177
Hi all
my 1978 z650, us import to the uk has been leaking oil from around the gear selector lever but only when the bike is on the side stand, it has been stood for almost 6 months and I have noticed the oil level sight glass is showing full, could the leak be due to standing so long? and is it possible to replace the oil seal without a strip down?.
thanks
1978 Z650 B2, US import to the UK
  • Nessism
  • Nessism's Avatar
Re: Oil leak
18 Mar 2025 05:00
#910179
The seal for the shaft is in the transmission cover, located behind the sprocket cover.  A fairly easy fix.  I suggest replacing all the seals in the transmission cover, to ward off future issues.
www.partzilla.com/catalog/kawasaki/motor...650-b2/engine-covers
The following user(s) said Thank You: SWest, Andyp62, Rolf1976_KZ900
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
Re: Oil leak
18 Mar 2025 11:16 - 18 Mar 2025 11:51
#910193
You may want to check more before changing the seals.You want to smell the oil, it may be gasoline in it and if it is it will leak for sure when standing a long time.You mention that oil is rising in the sightglass that is a big indicator that fuel has entered the crankcase .If a  floatvalve is leaking or a float is stuck it can happend that fuel dribbling into crancase when parked if the fuelpetcock also leak a little or if it not shut off.
Last edit: 18 Mar 2025 11:51 by Rolf1976_KZ900. Reason: typing
The following user(s) said Thank You: Andyp62, Kaw-boy 900
  • Kaw-boy 900
  • Kaw-boy 900's Avatar
  • Let the Good ''Old'' Time Roll !
Re: Oil leak
18 Mar 2025 11:51
#910195
You may want to check more before changing the seals.You want to smell the oil, it may be gasoline in it.You mention that oil is rising in the sightglass that is a big indicator that fuel has entered the crankcase .If a  floatvalve is leaking or a float is stuck it can happend that fuel dribbling into crancase when parked if the fuelpetcock also leak a little.
X2...I had the exact same issue. Check the oil color, mine was a bit green and smell gas !
Kawasaki and other bike ownend.
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Harley Softail 2009 For sale !
The following user(s) said Thank You: Andyp62, Rolf1976_KZ900
  • Andyp62
Re: Oil leak
18 Mar 2025 12:59
#910196
Thanks, will do
The following user(s) said Thank You: Rolf1976_KZ900
  • Andyp62
Re: Oil leak
18 Mar 2025 13:01
#910197
Thanks I will check that
  • Andyp62
Re: Oil leak
18 Mar 2025 13:02
#910198
Thanks that makes a lot of sense 👍
