Z1 timing vs compression question
- sf4t7
09 Mar 2025 05:05 - 09 Mar 2025 06:53
1974 Z1A
In the process of removing cylinder head and jugs I set the crank timing at T for cylinder 1 (in case it made a difference, which it doesn't on dis assembly) and noticed that the arrow on the exhaust cam sprocket was approximately 1 tooth ABOVE the gasket surface. (and I was so careful when I set the valve clearances! ). So my timing was about 6 degrees behind where it should be. (30 tooth cam sprockets). Cams were 28 pins apart as they should be. This got me wondering - would this +/- 6 degrees late be a factor in the compression being on the low side when I checked it beginning of the summer? (120 120 118 120) Rings aren't stuck, cylinders have no scratches, ridges or damage, crosshatching still visible. No smoke when running. Bore kit, pistons and rings have about 9000 miles since the work was done. (A leak down test earlier in the year was inconclusive, we had trouble with the motor rotating some when air pressure was applied at TDC, maybe we weren't doing it correctly). I was planning on replacing the rings while the engine is open, but I may not be able to find rings for the Yoshimura 69mm pistons, in that case I'll have to do a slight ball hone for crosshatch and re use the rings.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 09 Mar 2025 06:53 by sf4t7.
- Warren3200gt
Re: Z1 timing vs compression question
09 Mar 2025 07:02
Cam chain stretch will alter the cam timing marks.
The following user(s) said Thank You: asphalt900, sf4t7, Wookie58, Rolf1976_KZ900
- asphalt900
09 Mar 2025 08:26
Ditto Warren's thoughts, aged peanut 219 cam chain. Another possibility, make sure that little chain guide that attaches to the foreword cylinder assy is still intact. I've seen plenty of those fracture and fall in the oil pan.
The following user(s) said Thank You: sf4t7, Rolf1976_KZ900
09 Mar 2025 11:06With the "leak down" test once you have the motor in the position you want, select 1st gear and get an "assistant" to firmly apply the rear brake before you connect the air supply (in the car world we used the "E" brake) best if he rear wheel is clear of the ground just to be safe as it will still "kick" when you apply the air1974 Z1A
Agree with everybody else ref cam chain "stretch" the only thing I would add is that if everything else (guides etc) are OK and it has stretched that much, even though you are counting the pins the distance will have changed which will effect the cams position relevant to each other
The following user(s) said Thank You: Rolf1976_KZ900
- Rolf1976_KZ900
09 Mar 2025 12:43 - 09 Mar 2025 12:43
I had similar problem with timing on my bike .I replaced the camchain and sprockets. here is a pic from when i did the job the old camchain was about 5mm stretched
compared to the new.After replaced chain and sliders the timing was spot on.I did a quick writeup but have not posted it
Last edit: 09 Mar 2025 12:43 by Rolf1976_KZ900.
09 Mar 2025 12:59
Chains don't "stretch" as such, the extra length comes from wear in the pins and the holes in the links. If you lay the chain flat and bend it sideways this becomes clearly evident, the chain I removed from my diesel Jaguar had 45mm of side deflection at the centre of the "arc", the OE replacement had 15mm of deflection !!! worn pins is why they "break"
The following user(s) said Thank You: sf4t7, Scirocco, Rolf1976_KZ900
- Rolf1976_KZ900
09 Mar 2025 13:03
Yes that is true ,but if you look at my picks where i have compared old and new camchain they are longer to not just sloppy. Here is another camchain i replaced
09 Mar 2025 13:40
Rolf I'm not disputing that they get longer when worn, just clarifying the reason for the "growth" is wear not elasticity (stretch)
09 Mar 2025 14:17Rolf I'm not disputing that they get longer when worn, just clarifying the reason for the "growth" is wear not elasticity (stretch)
Correct. Chains don't stretch, they elongate, due to wear on the pins and related parts.
The following user(s) said Thank You: Scirocco, Wookie58, Rolf1976_KZ900, kimchella
- sf4t7
09 Mar 2025 19:50
Ok, i'll check the chain for extra length due to wear (probably a better term than stretch) and replace if needed. Asphalt900, the front chain guide was broken at the screw holding the upper end but was still in position held by the bottom. My main question was could the timing being off cause the lower compression numbers? Yes Guy, we didn't hold the rear wheel with the brake but I did have it in gear. Guess i've been spoiled by cars being held while in gear by their weight. Unfortunately that ship has sailed, the engine is apart.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: Wookie58, Rolf1976_KZ900
10 Mar 2025 01:26Yes, incorrect valve timing can effect compressionOk, i'll check the chain for extra length due to wear (probably a better term than stretch) and replace if needed. Asphalt900, the front chain guide was broken at the screw holding the upper end but was still in position held by the bottom. My main question was could the timing being off cause the lower compression numbers? Yes Guy, we didn't hold the rear wheel with the brake but I did have it in gear. Guess i've been spoiled by cars being held while in gear by their weight. Unfortunately that ship has sailed, the engine is apart.
10 Mar 2025 03:57
There is a method outlined in the manual to check for chain stretch. You hang the chain vertically with a weight (I think it's 5 kg) and measure 20 links against the standard length in the book.
In general, more than 1% stretch is excessive. For bicycle chains the stores sell an easy measuring device. Perhaps someone can come up with a similar device for timing chains?
