Iridium vs oem spark plug
- Maxbou92
06 Nov 2024 09:07
Hello guys, does it improve something to put BR8EIX instead of Br8es plug ?
Kz750e 1980
- Warren3200gt
Re: Iridium vs oem spark plug
06 Nov 2024 09:21 - 06 Nov 2024 09:22
Anything with an R in the title has a resistor built into the plug. If you already have a resistor in the plug cap it'll result in a crap spark whatever plug you use.
An iridium plug isn't going going to compensate for a 40 year old engine that isn't factory fresh.
Whatever plug is recommended by the fsm is what to fit or another manufacturers equivalent of it but definately NOT a resistor plug.
Last edit: 06 Nov 2024 09:22 by Warren3200gt.
- sf4t7
06 Nov 2024 13:54
IMHO, the only thing buying iridium plugs for an older motorcycle will improve is the seller's cash flow. I'm with Warren, use the fsm recommended plug or equivalent and avoid resistor plugs. Non-resistor NGK B8-ES are getting hard to find. I've had good luck with Denso W24ES in my Z1.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Maxbou92
06 Nov 2024 14:19
How do I inow if my cap has a resistor in it ?! And yes I cannot find B8es.. thats why I use Br8es. Does the Denso W24ES has the same température as oem ?!
Kz750e 1980
06 Nov 2024 14:21 - 07 Nov 2024 05:24
I agree with the others about avoiding an additional resistive element into the system. On some plug caps (never tried with the KZ flavor caps), the resistor can be removed, and replaced with a slug of copper.
Regarding a resistor plug hurting spark, realize, that some bikes used resistor spark plugs for some specific markets. Canada As long as the ignition system is working properly, I don't think a resistor plug is a tragic mistake.
Last edit: 07 Nov 2024 05:24 by Nessism.
The following user(s) said Thank You: Maxbou92
- sf4t7
06 Nov 2024 16:47
Yes, W24ES is the equivalent to B8-ES.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- daveo
06 Nov 2024 17:50 - 06 Nov 2024 18:35
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 06 Nov 2024 18:35 by daveo.
- Maxbou92
06 Nov 2024 18:08
Why do you have resistor cap with non resistor spark plug?! I just order 8 Denso w24es-u .. you have w27es ?
Kz750e 1980
- daveo
06 Nov 2024 18:29 - 06 Nov 2024 18:33
Last edit: 06 Nov 2024 18:33 by daveo.
- Maxbou92
06 Nov 2024 18:36
You run coller plugs for what reason?
Kz750e 1980
- daveo
06 Nov 2024 19:21 - 06 Nov 2024 19:31
U-Groove strap feature:
A member suggested that one step cooler plug would provide improved combustion for my engine setup.
The W27ES-U straps have a well defined burn area compared with the W24ES-U shown below:
Last edit: 06 Nov 2024 19:31 by daveo.
- ckahleer
06 Nov 2024 20:41
NAPA sells B8-ES plugs. The new NGK p/n is 2411.
www.napaonline.com/en/p/NGK2411
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
