Motor And Clutch Questions
  • MJinCO
  • MJinCO's Avatar Topic Author
30 Sep 2024 05:53
#904738
Several questions.  First does anyone have the bore to bore spacing on the KZ1000J motor?  I need to make a jug holder plate for putting in honing the cylinders in a honing machine, Should I use a top compression plate?Harley specifies using one?.  Second,  I'd like a second set of cylinders.  How late a cylinder set can I use in my case?  Lots of police sets out there.  Thirdly, off the motor subject, Current motor is 1075 and clutch slipping a bit at times coming out of turns, probably original, should I do any upgrades?
Finally running better, my oil temps with the German full flow bypass are still a bit high.  It takes about 6-8 seconds at idle for the oil pressure to come up due to the oil drain back I have.  That is acceptable to me.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Motor And Clutch Questions
30 Sep 2024 07:09
#904739
As I understand it any "J" series cylinders are interchangeable ("J"-"K"-"M"-"P" and KZ/GPZ1100) with the oil cooler I believe your fittings are at the bottom of the cooler - inverting the cooler so the fittings are at  the top will reduce "drain back" so pressure would come up sooner
With the clutch you could fit stronger springs, you can also "surface grind" the steel plates (they are stamped so usually have a slight "dish") which increases the surface contact (you may need to add an additional steel plate to maintain the overall "stack height") however in "bike powered" car applications the clutch is always a weak point and any clutch upgrades will put more load on the transmission (upgraded output shaft bearings are available from APE)
  • TexasKZ
  • TexasKZ's Avatar
30 Sep 2024 15:03
#904754
Automotive oil with friction modifiers can cause clutch slipping, as can maladjustment of the clutch cable.
  • Maxbou92
  • Maxbou92's Avatar
29 Oct 2024 13:35
#905564
Check on z1entreprises, clutch plates are available and cost nothing!!!! My kawasaki dealer want to sell me one plate at 20$ and z1entreprises are 5$ each one !! I put barnett spring with OEM plates.. it goes better than new in 1980!!!! Run rotella T4 (diesel) 15w-40. This oil is approved Jaso-Ma. (Wet clutch),
Kz750e 1980
  • Injected
  • Injected's Avatar
03 Nov 2024 12:07 - 03 Nov 2024 12:09
#905743
Just measured a new KZ1000 head gasket :
C-C between #1 and #2 = 3-5/8" between #2 and #3 = 5" between #3 and #4 = 3-5/8"
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 03 Nov 2024 12:09 by Injected. Reason: SP
