hunting neutral
  • 82KZ305Belt
  • 82KZ305Belt's Avatar Topic Author
hunting neutral
18 Sep 2024 19:26
#904441
Tonight I couldn't get the neutral light on so I could start the bike. It was in Neutral and it cranked, but the indicator light wouldn't come on and it wouldn't start. Eventually I got the light on and took a ride, by rocking back and forth and playing with the shifter. Had the issue again when I had to stop for a train, but once I got home and shut it off it seems to be happy again. I'm just worried this is the start of something going bad.
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: hunting neutral
19 Sep 2024 00:19
#904444
Could simply be the neutral switch is reaching the end of it's life - I wouldn't expect a "mechanical" fault in the transmission to be intermittent (generally speaking "if it's broke, it's broke")
  • 82KZ305Belt
Re: hunting neutral
19 Sep 2024 07:34
#904463
Thanks. I see a testing procedure in the manual so I'll run through that
81 KZ650 CSR
82 KZ305 CSR
  • H1Vindicator
  • H1Vindicator's Avatar
Re: hunting neutral
19 Sep 2024 16:29
#904471
It could be a loose wire or loose terminal.  you may have to crimp the terminal a little to get a snug fit. your motorcycle has a belt, so it may not be too dirty, but on a chain drive motorcycle the neutral switch and wire terminal get covered in chain sling gunk.
  • 82KZ305Belt
Re: hunting neutral
21 Sep 2024 06:27
#904501
My bike used to have a belt, but has had a chain for over 10 years now (see avatar).  So that's good to know. Yesterday it worked fine so maybe I can get through the season
81 KZ650 CSR
82 KZ305 CSR
  • H1Vindicator
Re: hunting neutral
21 Sep 2024 09:15 - 22 Sep 2024 07:04
#904504
you could go ahead and investigate the neutral switch. probably have to remove the LH foot peg and shifter so the chain cover can be removed. all very easy. have rags and solvent handy. it's probably going to be a mess.  a 30 min job at most is probably going to be maybe a couple of hours w the mess. or less.
Last edit: 22 Sep 2024 07:04 by H1Vindicator.
