Kz750e dyno
  • Maxbou92
  • Maxbou92's Avatar Topic Author
Kz750e dyno
31 Jul 2024 16:20
#902698
Hello guys, my bike just left the dyno.. somebody would like to know how many horsepower it gonna have.. so New engine oversize 0.5mm(150psi each one), vm28ss carburetor with pod filter, mild porting, milled head, 4-1 exhaust. 72whp 9500rpm and 43ft torque at the weel 8000rpm(12.3 to12.8 AFR). Don’t know if its good.. my clutch is slipping like hell with Rotella 15w-40 ?!! Dont know if its the clutch or oil?!
Kz750e 1980
The following user(s) said Thank You: Nessism, Wookie58
  • Injected
  • Injected's Avatar
Re: Kz750e dyno
31 Jul 2024 17:30
#902703
The claimed factory rating for a 1980 KZ750-E1 with stock parts was 74 HP SAE (at the crank) A rating at the wheel is usually 10-12% lower ( = 66 to 67 HP) They did not mention torque but I would guess around 40 LBFT. You gained a little bit of HP with exhaust and carb swap, seems normal to me.
1978 KZ650B2 modified project
  • Nessism
  • Nessism's Avatar
Re: Kz750e dyno
31 Jul 2024 17:44
#902706
That sounds excellent to me!  I'm surprised it's that much.  Sounds like a sweet ride!
The following user(s) said Thank You: Maxbou92
  • Maxbou92
Re: Kz750e dyno
31 Jul 2024 17:51
#902707
Thank you, for my clutch. What are you thinking? Oil or clutch ?
Kz750e 1980
  • Maxbou92
Re: Kz750e dyno
31 Jul 2024 17:51
#902708
Kz750e 1980
  • Nessism
  • Nessism's Avatar
  • hardrockminer
  • hardrockminer's Avatar
Re: Kz750e dyno
31 Jul 2024 19:39
#902713
I use Rotella in my bikes with no clutch issues.  Just make sure the oil has the JASO certification.
  • Maxbou92
Re: Kz750e dyno
01 Aug 2024 00:19
#902720
I already have nee Barnett clutch springs.. and the diesel oil is rated Jaso . The clutch slip in high gears at 7000 rpm
Kz750e 1980
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Kz750e dyno
01 Aug 2024 00:33
#902722
This would suggest an adjustment or cable issue (not enough "free-play") if the clearance is too small the clutch will heat up and reduce the clearance further (like resting your foot on the pedal in a car)
  • Maxbou92
Re: Kz750e dyno
01 Aug 2024 00:38
#902723
I tightened the adjuster nut and backward 1/2 turn. I have a big free play on the handle!! New cable too. Soo weird
Kz750e 1980
  • Nessism
  • Nessism's Avatar
Re: Kz750e dyno
01 Aug 2024 06:50
#902742
With age and mileage, the fiber plates are known to petrify.  It may be time for a new set.
  • Maxbou92
Re: Kz750e dyno
01 Aug 2024 07:19
#902745
  All right, I will put my new Kawasaki Fiber plates soon!!
Kz750e 1980
