Kz1000p case crack
- Lpar
17 Jul 2024 07:18 #902257
by Lpar
Replied by Lpar on topic Kz1000p case crack
I tore apart the other donor engine, no cracks on that one but someone did a pretty rough job cleaning up the mating surfaces for the case, and I'm not sure I want to use that one. Obviously TIG welding the crack would be best, has anyone had any experience with brazing aluminum?
- Thank you received: 2059
17 Jul 2024 13:31 #902276
by Scirocco
Replied by Scirocco on topic Kz1000p case crack
- Thank you received: 2738
17 Jul 2024 13:41 #902277
by SWest
Replied by SWest on topic Kz1000p case crack
AGREEAs already suggested before, you should have go the "sleeve way".......
