- Thank you received: 35
Anyone want to collaborate on a GPz550 runs like crap flow chart?
- chopper1963
02 Jul 2024 08:45 #901660
by chopper1963
Anyone want to collaborate on a GPz550 runs like crap flow chart? was created by chopper1963
I think it would be good to have one, and not just because I have one on my stand that runs like crap.
We could do it here and then if everyone is cool maybe make it a sticky?
Thoughts?
Thoughts?
- Stereordinary
- Thank you received: 143
02 Jul 2024 09:18 #901661
by Stereordinary
A breeze from the west.
‘90 ZR550 Zephyr
Replied by Stereordinary on topic Anyone want to collaborate on a GPz550 runs like crap flow chart?
I could try to help. One of my Zephyrs (KZ550) runs, but the acceleration is abysmal.
‘90 ZR550 Zephyr
- Thank you received: 2810
02 Jul 2024 09:48 - 02 Jul 2024 13:16 #901663
by Nessism
Replied by Nessism on topic Anyone want to collaborate on a GPz550 runs like crap flow chart?
Start here...
www.kzrider.com/forum/forum-index/faq-wi...owner-things-to-know
The majority of running problems trace to (lack of) maintenance, or mods gone bad.
Just my opinion, but making a flow chart that tells people to make sure they don't have rust in the tank, or to rebuild their carbs, properly, adjust the valves, etc, seems like a backwards way to approach the problem.
Last edit: 02 Jul 2024 13:16 by Nessism.
- chopper1963
02 Jul 2024 16:52 #901669
by chopper1963
Replied by chopper1963 on topic Anyone want to collaborate on a GPz550 runs like crap flow chart?
Let's start here:
A good battery should put out at least 12.8 volts (?)
Ignition coils should register (?) Ohms
- chopper1963
02 Jul 2024 16:54 #901670
by chopper1963
<<Just my opinion, but making a flow chart that tells people to make sure they don't have rust in the tank, or to rebuild their carbs, properly, adjust the valves, etc, seems like a backwards way to approach the problem. >>
I wasn't going to make a flow chart about rust in the tank or adjusting valves.
Next: Minimum cylinder pressure should be 120 psi as measured with a compression gauge.
- Thank you received: 2224
02 Jul 2024 17:15 #901673
by TexasKZ
Replied by TexasKZ on topic Anyone want to collaborate on a GPz550 runs like crap flow chart?
If I was gonna make such a chart, it would look like this……..
1. Do all of the routine maintenance items listed in the factory service manual.
2. Do ALL of the routine maintenance items listed in the factory service manual.
3. DO ALL OF THE ROUTINE MAINTENANCE ITEMS LISTED IN THE FACTORY SERVICE MANUAL!
4. DO ALL OF THE ROUTINE MAINTENANCE ITEMS LISTED IN THE FACTORY SERVICE MANUAL, YOU BLOCKHEAD!!,
The following user(s) said Thank You: ThatGPzGuy, slayer61, sf4t7, howardhb, Kelly E
02 Jul 2024 17:44 - 02 Jul 2024 17:45 #901675
by Nessism
BTW, no load tests on batteries are not meaningful. Sorry...
I realize that you are trying to help, but this info is in the factory service manual. People should ALWAYS use the manual as their bible. Not some info they find on a motorcycle forum, which may or may not be correct.Let's start here:
Last edit: 02 Jul 2024 17:45 by Nessism.
- Nerdy
- Thank you received: 407
02 Jul 2024 18:34 #901676
by Nerdy
I don't get it. What the heck are you trying to say??
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Replied by Nerdy on topic Anyone want to collaborate on a GPz550 runs like crap flow chart?
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
- chopper1963
02 Jul 2024 18:38 #901677
by chopper1963
<<I realize that you are trying to help, but this info is in the factory service manual. People should ALWAYS use the manual as their bible. Not some info they find on a motorcycle forum, which may or may not be correct.
BTW, no load tests on batteries are not meaningful. Sorry... >>
Then why is that very information listed in the factory service manual/bible?
03 Jul 2024 07:20 #901695
by Nessism
@chopper1963, please forgive this post. It's NOT directed at you.
All over the internet's motorcycle sites for older bikes, we see the same thing repeat: dude finds a bike that's been sitting for an indeterminate period of time. He installs a new battery, changes the gas and maybe oil, then scratches his head when the bike doesn't start up and/or doesn't run right. A Youtube video often follows, with the bike, maybe, running on half of its cylinders, while gasoline pours down from the carbs and/or airbox. "Now what?" the caption reads.
- Stereordinary
03 Jul 2024 08:54 #901702
by Stereordinary
‘90 ZR550 Zephyr
Replied by Stereordinary on topic 91 zr750 8800 original miles beautiful
Now that I think about it, my FSM has a troubleshooting section at the back of the book. It’s pretty close to a flow chart.
‘90 ZR550 Zephyr
- slayer61
- KZR FLAG RELAY CARRIER #62
03 Jul 2024 11:26 #901708
by slayer61
Replied by slayer61 on topic Anyone want to collaborate on a GPz550 runs like crap flow chart?
I work in a power plant. I have tried to tell many folks it's like a giant car. It has a starter, it has a lube oil system, it has a cooling system. Hell... it even has a generator!
The point I'm trying to make is this... when we do a "start up", we look at ALL the "systems". First we need a solid connection to electricity. 15KV breaker serving the plant... check.
The hydraulic system needs to work, for the starter to work.
The cooling system & lubrication systems need to be up to snuff in this weather or we're stuffed...
Ad infinitum until you've covered everything involved.
The need to look at the bike system by system is vital for a successful start up! As they say... "YMMV"!
