Gpz550 ignition issue
- Ant_5445
13 Jun 2024 05:45 - 13 Jun 2024 05:47
Got a weird problem on my hands that im trying to get to the bottom of. '81 gpz550 with a set of CR26 carbs on it, runs good, pretty peppy on the road, however i've noticed a couple times that it'll have a weird idle to it. Messing around the other day and i pulled off one of the spark plug boots on cylinder 4 and there was no noticeable change in the idle. Now, when i do the same thing to the other 3 cylinders the idle goes low and the bike stalls, naturally. Now the weird thing is that I've touched the cylinder 4 pipe and its the same temp as the other ones when idling, so it seems that it is firing? I've cleaned the pilot jet with no change. I've checked spark on cylinder 4 and even swapped plugs, coils, spark plugs, wires ect...no change. Is this a deeper issue like valves needing adjustment?
'99 Zrx 1100
'81 Gpz 550
'81 Gpz 550
Last edit: 13 Jun 2024 05:47 by Ant_5445.
Re: Gpz550 ignition issue
13 Jun 2024 05:53
Have you checked valve clearances and compression (sounds like one cylinder isn't working as hard as the others)
- Ant_5445
13 Jun 2024 06:31
Thats what my next step is going to be when i get home later. Ill check compression first then continue on if that checks out, maybe even throw a new spark plug at it just for the hell of it. Might have to hold out and find some time to check the clearances though.
'99 Zrx 1100
'81 Gpz 550
'81 Gpz 550
13 Jun 2024 06:36Tight valves will effect compressionThats what my next step is going to be when i get home later. Ill check compression first then continue on if that checks out, maybe even throw a new spark plug at it just for the hell of it. Might have to hold out and find some time to check the clearances though.
Loose valves will mean reduced opening time so less flow "In" and "Out"
- Ant_5445
17 Jun 2024 12:01
Ended up being a clogged pilot jet which was strange because that was the first thing i tried was taking the bowl off the carb when it was on the bike and squirting some carb cleaner through it...i guess i just needed to take the whole carb off and do a better job at cleaning. Then i was in such a hurry to make it somewhere with the bike that i forgot to re install the pilot jet! No wonder why it was still acting up on me afterwards and making me scratch my head haha!
'99 Zrx 1100
'81 Gpz 550
'81 Gpz 550
