- Thank you received: 15
Oil in #4
- OkieZ1000
14 Jul 2024 15:02 - 14 Jul 2024 15:02 #902116
by OkieZ1000
Replied by OkieZ1000 on topic Oil in #4
Here's where I'm not sure about the lack of markings on the top ring.
The "N" ring came frome the "wiper" (2nd ring from the top) and is .045 in thickness.
The compression (top) ring doesn't have any marking on it and is .038 thick.
The piston grooves won't take the "N" ring in the top groove.
The top ring has a slightly raised outside edge that was installed facing down (as are the other 3 cylinders)
Last edit: 14 Jul 2024 15:02 by OkieZ1000. Reason: Typo
The following user(s) said Thank You: Rolf1976_KZ900
- Rolf1976_KZ900
- Thank you received: 159
14 Jul 2024 15:27 #902117
by Rolf1976_KZ900
Replied by Rolf1976_KZ900 on topic Oil in #4
The following user(s) said Thank You: OkieZ1000
- Thank you received: 2301
14 Jul 2024 17:01 #902119
by Wookie58
Replied by Wookie58 on topic Oil in #4
Could you hear any escaping air during the leakage test ? (Oil filler hole etc) is there any sign of leakage on the gaskets from the oil passages around the outer studs ?
- OkieZ1000
14 Jul 2024 19:17 #902124
by OkieZ1000
In the leakdown, you can hear the air from the crank case vent.
I did replace all the seals between the jug and the head (dang those things were expensive)......
- F64
- 81-KZ440D2
- Thank you received: 394
14 Jul 2024 23:13 #902128
by F64
81-KZ440-D2.
LIC, NY
Replied by F64 on topic Oil in #4
This also gives you the opportunity to have the cylinder plateau honed if you want.
www.enginebuildermag.com/2023/01/honing-the-ls/
81-KZ440-D2.
LIC, NY
- howardhb
- God, I trust
- Thank you received: 469
14 Jul 2024 23:41 - 14 Jul 2024 23:45 #902129
by howardhb
'81 GPz 550 D1
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/our-forum/11-projects/61...-elr-tribute?start=0
'82 Yamaha YB100 Fizzie
Replied by howardhb on topic Oil in #4
When in doubt, consult the manual!
(the "N" mark denotes the second compressin ring)
Oil control rings, install like this:
For the "expander" (wavy part) of the oil controll rings, make sure that the ends "butt" together and do not "overlapp".
H.
H.
'81 GPz 550 D1
Last edit: 14 Jul 2024 23:45 by howardhb.
The following user(s) said Thank You: Scirocco, OkieZ1000, Wookie58, Rolf1976_KZ900
- Rolf1976_KZ900
15 Jul 2024 00:52 #902130
by Rolf1976_KZ900
- Rolf1976_KZ900
15 Jul 2024 01:40 - 15 Jul 2024 01:44 #902131
by Rolf1976_KZ900
Just to add If the second ring is placed upsidedown i will push oil upward instead down to crankcase.The ring has a chamfer / angled edge to keep it sharp as the ring wears into cylinder wall. If the ring is worn the chamfer /angle will be gone and the edge of ring gets 90 degree straight .If you placed the old rings into the bore again and also did not deglase the bore it is very big chance that it will be a oilburner.Thing you should do is measure the bore for taper and out of round and piston to wall clearance. If you are lucky you can just deglase the bore with a ballhone or / stones put new rings on and ride.If you dont have a boredial gauge you can buy a set of new rings and put them in the bore and check that endgap is in spec or at least close to spec.The piston to wall clearance can also be measured by using feelergauges not 100% acurate but it works.I did check that when i rebuildt the kz900 engine.I also used a boredial gauge but for fun checked if the feelerblade method is usable and it is ,for piston to wall clearance but not for measuring out of round or taper
Last edit: 15 Jul 2024 01:44 by Rolf1976_KZ900.
- Thank you received: 1088
15 Jul 2024 03:38 #902132
by hardrockminer
Replied by hardrockminer on topic Oil in #4
There should be holes in the bottom ring groove to allow oil to flow back to the sump through the inside of the piston. Are the holes all clean?
- OkieZ1000
15 Jul 2024 07:32 #902141
by OkieZ1000
That's a good question, I'll check that and compare to the good cylinders.
- asphalt900
- Thank you received: 274
15 Jul 2024 09:20 #902145
by asphalt900
Replied by asphalt900 on topic Oil in #4
From a glance , liner looks pretty shiny. You're over thinking and second guessing yourself, just hone and purchase a fresh "sharp edged" new set of rings. They are an abundant supply out there, NPR, OEM, etc. Might as while buy a set of 4 after all the time you've wasted assembling/disassembling.
The following user(s) said Thank You: sf4t7, OkieZ1000, Wookie58
- OkieZ1000
15 Jul 2024 12:22 #902159
by OkieZ1000
I do think a hone/ring sounds like a fairly inexpensive plan.
Since I don't have many miles on the rebuild, should I spring for a new head gasket or can I just reuse?
I also wonder what might have happened in it's previous life to have such a low mile bike in this condition?
