1978 kz 650 sr - rocker cover removed - questions about service to top end
- chopper1963
Re: 1978 kz 650 sr - rocker cover removed - questions about service to top end
22 May 2024 05:27
Where is the video?
22 May 2024 05:56My understanding is this is to avoid damaging the tach gear when you pull the cam back down on reassembly due to misalignmentThanks Ron. I just watched a video that the guy did exactly what you are saying. You are correct about my tensioner, apologies I referred to it as automatic but yes you are correct. the factory manual says to remove the tensioner and the tach gear for some reason? i think thats more geared toward removing the whole head tho?
The following user(s) said Thank You: xstreamcanadian
- xstreamcanadian
22 May 2024 08:48
Wookie
Yes agreed but from what I could see of my configuration damaging the tach gear would be difficult. As the exhaust cam lays down it meshes perfectly, and either way youd have to re install the tach gear prior to the cam anyway I think? I just left mine and used assembly lube on the cams and the tach gear and a little on each bucket. it seems to operate much smoother now too, not sure if thats in my mind or not. thanks again for all of your help sir
- xstreamcanadian
22 May 2024 08:50Where is the video?
its on youtube? it wasnt a great one and skipped a few steps so I didnt save the link. there are plenty on there if youre needing to watch one
22 May 2024 09:08I think to be fair, with care and experience there are many steps in all manufacturers service manuals that can be and are "by-passed". The thing to keep in mind is that these manuals are written for a diverse demographic of readers and where possible the authors try and "protect the luddites from themselves"Wookie
- xstreamcanadian
22 May 2024 09:42
ha ha yes. I am one of those luddites sadly from time to time but with the manual and you guys I am coming out of the dark into the light
